super close to buying a set of pentagrams
ppl who have them: is it worth? what tires you using? liking the extra width?
currently running BN GT3 and they’re great but i kinda wanna go wider
can i use kaly phat tires with your hubs?
I’ve heard that since these are designed for the tighter bead of xcell tires, they can be very unbalanced with tires like Kenda (that work great with BN GT3, which are slightly too large of diameter for xcell tires).
Nah you just gotta center them well. Pump them up to 5 psi and go from there
3d printed 9 inch lip spacer:
please print it by using PLA, 0.2mm,100% infill
File download:
newbee rim spacer.stl (330.5 KB)
What are those tractor tyres??
Those are from alibaba, wear out really quick…about 70km…the rubber start peeling off.
Good fun for deep mud for a while I’m sure.
Got a link?
Does this work for you older pentagram rims?
Fit the old 9-inch version, but you could print a spacer on, to make it fit. PM me if you want the file, or i can print it for you.
Photos from our sponsored rider @health Lewis
He will testing how our rims performance on high speed.
diameter? ID? Like for a 10mm or 12mm axle?
I think they mean the axle diameter, I chose 12mm and it was the right size for apex airs…
@Ean.esk8 I’m going to put 7" tires on my pentagrams. They will be stretched pretty wide. Should I use 7" or 8" inner tubes?
I’ve got 7inch tubes in my 7 inch Evolve tyres stretched onto the Newbee Pentagrams. Been running these for quite some time without issue. Just my experience.
could I see a pic?
edit: found em in your other post! looks great
