They ride like the 4gd
Since I don’t think there are any other mounting options, are the gear drives going to be available to purchase alongside the trucks or will they need to be ordered separately?
They will be listed separately, with a discount available if both are added to the cart.
The clamp used for these trucks are the same as the Trampa trucks so I will adjust the website accordingly.
That’s good to hear! My MTB will be topped at like 30-35 so not too worried about stability, just want to be able to carve hard on trails.
One question it is possible to reverse mount 63100s on your trucks and drives right?
what is reverse mount again?
Like with the motor on the kingpin side of the truck.
Edit like this
Yes it will be fine
I thought the kingpin would limit max motor length a lot, 100mm fitting is amazing!
moon trucks + 5:1 helical gears + 63100 = best drivetrain 2021
Does this mean I can buy extra low angle bps from you and use them on my caliber setups?
So all the Trampa motor mount/drive stuff should fit more or less?
yes
yes
Once again, Moon for the win.
Gears galore, restock is expected mid Jan.
I made a small amount of 8T straight cut pinions in this batch and I am looking forward to testing them out. That would bring the shortest gearing ratio to be 5.5/1.
tooooooooooooooorque
Im not rebuilding my gear drives until I get these!
YASS, I need
what mm bore do those 8T have?
8mm only. The pinion is so small I had to make a custom key for them
What’s lighter, your trucks or Matrix 2’s?
