Batch 6 drives will be listed from Sunday 18th July 19:00 BST
Do you have any raw finished ones ![]()
Could you point me to the list of available gearing options for this batch? Or is the website up to date already?
Everything highlighted in green
8mm and 10mm bores for helical 10T pinions
8mm only bores for steel/steel configs
What’s the best proven ratio for 105kg person on Lunas metro 155 that likes to cruise I don’t want crazy torque and I also don’t want crazy speed but want to be able to start from a stop with no issues and cruise at
40-50km
That answer probably depends on a lot on your motor kv, your usual power consumption on your usual rides, and your battery config.
All the moon drives are proven in a sense, but there’s too many variables to provide a single answer. Plug your numbers in and play with the calc:
https://calc.3dservisas.eu/
I’d gear it for your target max speed and see what it gives you. From past experience, 40Nm max torque seems to be a super torquey setup, while 25Nm is all top end speed (roughly). If that helps
If you want a chill board to cruise with, then getting the lowest gear ratio will give you best free-roll. On Batch 5 that appears to be 47:14, which on 12s and 155mm metros means 170kv motors would give you a nice minimum speed of 48km/h.
On the other hand, for best braking power and acceleration, you’d want the highest gear ratio possible. So idk
Edit: subtract 2km/h from those numbers if you go with 165kv and that ratio. Those are pretty big motors, so honestly you might already have enough torque for your needs
Edit 2: if I were you I’d pick up an extra set of pinions for a really high gear ratio in case you switch your setup / sell your drives off later down the line.
Bro, with as many builds as you have, I know you can plug some numbers into a calculator lmao
I don’t know if that’s a thing but, with all the gearing available for this drive or any other drives, is it possible that some ratios won’t be appropriate for certain motors kv? Like if would run hotter or something like that?
For typical esk8 motor kvs and sizes, running faster and with proportionally less current is almost always more efficient for the motor, so the highest gear ratio would be best in that regard. Nacho’s motors are massive though, doubt that’s a concern for him.
I’m a feel and touch kind of guy I do look at ratios a lot and I just like others feed back
Ratio 3.0
These are @Janux-esk8 older generation and the free role sucks but everything else is awesome just trying to get as much info from here as possible
Best way is to pick your max top speed and then see what gearing you need to achieve it with the battery/motors/tyre size taken in consideration
those r literally perfect
Which is better ??
Spur gear?
Helical gear?
I don’t
Helical gears are silent as belt drives.
Spurs produce an addictive noise that can be heard from everyone around you.
My helicals sounded better than belts
No Helical gears for batch 4?
