Think he was referring on aluminium on aluminium, or aluminium on steel, which is indeed a bad choice judging by how belts chew up alu belt pulleys in a month max.
Aluminium on plastic might work because it’s the harder material between the 2
please take this convo elsewhere
Supports 6.5-10" tyres
1 inner and 1 outer rim weighs approx 225g
2WD setup weighs 919.7g
4WD setup weighs 939.4g
Moon rims have dual mounting and use M4x16mm and M4x10mm bolts. You will be able to pressfit these rims onto the moon drives for easy installation/service.
Rim size is comparable to Phatlads.
Phatlads Spec:
1 inner and 1 outer rim weighs approx 180.5g
2WD setup weighs 816.3g
4WD setup weighs 910.6g
Phatlads have dual mounting and use M4x45 and m4x50mm bolts
No, gears bearings anything wheres friction for longevity the materials must be the same, or at least the same hardness so the wear is equal on both sides
Anyways lets not derail this
Perfect! And what’s the width?
46mm
Thanks man
Woah these look fantastic mate well done
I really need those hubs please put me on the list for a set in raw. I’m going to paint them in a custom color.
Building a flux motion board with what I hope to be my (personally) ultimate board, apex truck in front and moon truck in the rear with the geardrive, just waiting for the geardrive restock and truck drop desperately.
Cannot wait to ride my new board with geardrives!.
Why two different trucks? Moon drives work on Apex Airs
So when can I order these trucks, is there a list already?
Is there any information on what motor bolt patterns are supported by the moon drives? IE TB6380s have two different bolt patterns and the flipsky 6384s only have 1 pattern. I think FS6384 only has the larger pattern of what is on the TB6380.
I couldn’t find it on the site but maybe I overlooked it.
Outer hole pattern is what is similar on most of the 63xx motors and fits on moon drives.
Both of the motors you mention will fit.
Yeah I think thats going to be quite weird! Keen to see what happens
Can I be a tester for the wheels?
Bushings arrived today along with boxes for the trucks.
Drives arrive tomorrow
Fasteners arrive the day after.
Will announce date and times of the release so people don’t miss out.
Sorry mate, I made a limited amount with testers preselected.
