Hi everyone.
I want to introduce to you the 200 x 75 mm Phatty tires.
I’ve been testing and having fun with this for a while now and will be selling this HERE.
This tires grip the road like glue and makes all the crappy roads feel smooth also behave way more stable at high speed.
Since @DerelictRobot wanted some Phatty for his LOVE CHILD I’ve design an Aluminum 7075-T6 hub fully compatible with his drive train.
This HellCat hubs are paired with 2 Double row angular contact bearings to give the best performance and reliability.
Also are equipped with my HANDSHAKE bracing system to provide extra rigidity like no other hub.
The system is fully compatible with the MBS.COM Matrix II truck system and 12.00 mm axle.
Also this can be install on any system currently using the MBS Rockstar II Hub without any modification to the system, just take off the tire you have now and pop this one in, that easy
Since we are on the MBS.COM Rockstar 2 hubs, I have made and high performance option for it.
It is compatible with any system currently using the Rockstar 2 hub.
Using 2 Double row angular contact bearings for the same safety reasons.
And the HANDSHAKE bracing system to provide extra rigidity.
This are available for preorder on this links below, will only make a limited quantity of this hubs.
HellCat wide 200 x 75
HellCat 200 x 50
Hope you guys like it and any comments let me know here.
The tires and hubs will be coming in 6 weeks at the latest.
