It shouldn’t be. Lower charge rates reduce heating and can help to extend cell life.
Christ…
Why only 2amps?
The 12s packs I have currently are small.
12s3p 30q and 12s4p 40t. So I like to just keep at 2amps on those and have 3 chargers… All 2 amps.
time to make a 3way split charger? for science and giggles
2way exists.
yet to see the carzy one among us do a 3way
The two chargers are hardwired in parallel to the pack?
That would be 20amps for my 48Ah pack. Thank you very much
Charger here :https://forum.freesk8.org/t/the-last-power-supply-youll-ever-need/276/41
(Other forum had more info)
Battery here : 12s7p Qb26800 "That's Two KiloWatt Hours" Topmount
Will P42A batteries get hot if charging 3A/cell?
Datasheet states that standard rate is 4A.
Just wired them in parallel, 3 way definitely possible, but I don’t have another charger and the GX-12 would probably melt
Even if there is a voltage mismatch, it works, what happens is that the slight lower voltage charger turnoff as soon as you plug both together, a few seconds later it try again and this process repeats until the FlexiBMS engages the charging
Same thing as if you plug an adjustable charger in a pack that is higher voltage than the set point
Nothing blew up, need to discharge the pack to 0 and do a lot of the full charge time to see if anything gets too hot
But even at 10A is not that much for the 30Q, only 2A/cell, will degrade faster? probably, but as I said I will almost never use this setup
I think this range is common for the street boards but once you start to consider all terrain boards with 12s8p packs and larger then 4A just isn’t enough.
For people on 8P+ then 8A,10A &12A chargers are easy to get hold of. After 12A it becomes hard to find chargers capable of that much power without being huge or looking like a server PSU.
Personally I have a 4.5A charger for my 18s4p p42a pack, but it takes over 3.5 hours which is to long to hang about at a pub mid ride. I have been trying to work out a better charge solution but not worked it out yet.
12s6p 30q 8a charging
I like what you did here. Pretty simple
For me it goes like
12s10p 35e 10a Charger on the go and 6.5a at home
I feel like 4a is not enough for a pack that big. Besides taking a long time to charge it won’t go pass 92% witch wasn’t the case with same charger and smaller packs
My 8P 30Q brick is warm charging at 8A. You notice any heat? I’m not sure your cell layout either tho.
I charge 4a for my 12s8p 30q and mine stays cool as a cucumber
I dont really know. Ive had the pack for about a month and only had to charge a couple times
What is “hot” for you?
3A is below the standard charge rate so you would expect that they wouldn’t get warm enough for their cycle life to be affected too much more (versus lower current charging). But, you have your cells wrapped up in a pack and you will have to measure the temperature of any inner cells (or whichever get the warmest) to see if 3A/cell is an issue. Someone with a similar pack might have done that though.
Staying below 45°C is a good target for the warmest cells.
Yeah if I stick it on my 3A backup charger no heat. But the 8A and its noticeable. But it is a brick so im sure that’s trapping a lot of heat in general
And the internal temps will be a lot higher than what you feel on the outside.
Yeah, im not overly concerned. I dont think it’s reaching any hotter than it is during discharge. I’ll have to measure it next time. I’m guessing 35*C in the center of the brick.
Yup. For this reason I adjust to charge at 38 or do measured C. This also greatly depends on how the thermistor is in the pack
