Hey guys,
sinde a longer time I’m looking for a silent, cheap and torquey solution for my second mountainboard. So is designed a gear drive in a similar shape as this belt drive. I used existing parts from Mädler to keep the cost low but relealized later that the gear may not hold (cheap machining steel). These have been helicals. So I upgraded the construction to hardened gears. These were straight cut and a lot wider. As I like a silent drive I came up with this one here (which is not realley wider than the second gear drive version) which I will finally build now
As 190 kV is kinda the standard for esk8 motors nowadays you need a high gearing for a mountainboard because the topspeed would be useless high and you’re not using the full torque potential. Higher kV motors also have a lower resistance, so you can push more amps through it, which means even more torque.
The most common gearing in mountainboards is 1:5. With 190 kV this is not enough in my opinion. So I used the concept of multiple gearing, which gives me a gearing of 1:7 for this belt drive system.
Features:
- High gearing (1:7)
- Very good clearence
- Completely sealed
- Silent operation (hopefully
) - Low maintenance
- Pulleys are secured with a keyway
- Seperate cover for easy adjustable belt tension
- Positioning angle is adjustable
- No need to machine the truck
The clearance is similar to a 1:4 gear drive or a 64T belt drive without cover. Especially the high gearing drives from Trampa (belt drive and spur gear drive) have a very low clearance.
Materials:
- Stainless steel (plates, Superstar adapter, shaft, bolts, bearings)
- 7075 aluminium (rods, spacer)
- plastic, 3D printed (wheel pulley, pulley adapter, wall between plates)
The drive is designed to fit Trampa Infinity and Vertigo trucks. Other trucks would be easy adaptable (just need to change the truck adapter). I just designed the hub adapter for Trampa Superstar hubs, here others would be quite easy adjustable aswell.
The drive is relatively heavy because I will use lasercutting for the plates (cheap), therefore the material will be stainless steel and no light 7075 aluminium. I maybe upgrade that later.
I think such a drive system is perfect for high kV motors in combination with a mountainboard (never enough torque
). Especially when you switch to 9" tires you loose a lot of torque. This is where this design really comes into play. The gearing is easily changeable to even higher ratios. 1:8,5 needs just a slight increase in size of the whole drive.
Here are some more renderings. Some small things might change for the final version.
Sorry for beeing lazy and not adding the second side and the most bolts
I ordered the most parts with a rather long shipping time. Next week I will finish the construction and will order the laser cut parts. Hopefully end of march I can start with some test
Let me know what you think of this project!
