I am losing hope in my neobox order. When can I order a Zesc6 pro?
Is there a reason the ebay listing is $999?
14awg for power cables?
When I sell them I will use 12awg.
They look really smart. Good job.
looks awesome! What’s the price?
v2 pro (aluminum housing) is $120 each.
what’s the height with heatsinks?
and any chance of a mirrored version?
When is going to be available?
total 20mm
Any chance to make this waterproof? Such a beauty should not be hidden under an enclosure.
not an easy task
Take my money
The power wires look like they are at risk of shorting when you have them going through a slot in the heat sink…maybe a rubber ring recessed in there would be better?
don’t worry. I considered this when designing it. there is an over 2mm gap between the solder joint and aluminum case. I will find a more reliable isolation method.
That’s gonna be with the thicker 12awg wires?
yes, the case is designed for 12awg wires.
So tidy, just not keen on using proprietary fw though.
all it takes to fix that is a pull request
