If you get that STL, post it here please if possible. Would be nice to print a couple to have as backups. The ones in mine seem quite solid
https://drive.google.com/drive/folders/1xIki8Va7csDLZioS8XXyRiNCxYaiRNRz?usp=sharing
He said most remotes are m3, but some of the newer ones are m2
Yeah mine is M2. Thank you. Attached are STL versions in case anyone can’t open a 3mf file.
Zmote_M2Lever.stl (125.0 KB)
Zmote_M3Lever.stl (90.7 KB)
We’ll get to it
I’m so busy rn, once I finish up some big jobs, I’ll have time for fun stuff.
Curious what people think would be nicest. We’ve talked about metal frame with pom panels, the opposite, or metal with wood grips.
Yeahhhh this is the one I suggested ![]()
All this would be nice, but TBH, you’d get 99% of there way there if someone did a print run of MJF shells, and maybe swap out some of the fragile parts too for aluminum or MJF.
I enjoy my MJF shells every bit as much as production run nylon counterparts, but the current 3dp on the zmote definitely has a DIY feel.
I want…I want!!
But I want that luxxxxxe feel lol
I’m sure Kamen would supply the shell if someone wanted to do the MJF run
Polycarbonate side panels with gunmetal trim that stands off far enough that the clear panels are safe in case of a slide ![]()
I recently bought a bunch of electronics for these to make some with MJF shells. I should have the project wrapped up in another month. Kmann has been extremely helpful. I’m excited to try these remotes made with fiberglass filled nylon MJF.
I’ll have twenty all together. Imma use them for some builds that I have going on, but I’ll have a bunch to sell.
Bought a z-mote used and I couldn’t find any info online.
How do I pair the remote? Or do I not have to cause they have a unique rf address?
Scroll up to post #322
Thank you
Really want to give the dual trigger a try. Patiently waiting for them to return
Finally got mine together. The throw on it is nice, feels good in the hand, and its pretty lightweight. Love the look of it too. I did switch back to a voyager temporary for the telemetry until the Megans are available.
Anyone know what radio module/protocols the z.mote is using?
Esk8con experience with the zmote split trigger was great.
I was a little worried about how signal integrity would hold up around hundreds of other riders, and riding through the vegas strip.
No issues at all. Not a single blip of cutout or ghost signal. Zmote continues to have a 100% perfect record for me.
Agreed! I used it all weekend racing, and at the strip group ride. Not even a sign of cutting out/disconnect.
