I love you. Laughing in the face of overwhelming strength and intelligence. You’ve got balls if nothing else
We will speak of his bravery at his funeral. It will be closed casket because they couldn’t get the EUC back out out of his anus due to all the JB Weld.
ROFL. I hate JB Weld, epoxy FTW.
Serious replies?
This is my actual order sheet modified slightly to fit total.
Things on it will probably change by the time I spend all that money. (Not the forum stuff or TB tho)
Fuck I didn’t write their usernames right
This makes no sense to me
Yeah I’m confused myself a little bit. The goal is to have:
2 TB deck’s one with 25R and one with 30Q
Boardnamics kits on both those.
Then I’ll have dual TB 6355 and 6374 for them and 97mm for street and 190mm pneumatic for AT.
For ESC I could do many things. I’ll get the TB vesc for the AT board, and the 6355 will only be 40A each so makerX maybe.
What are you riding now?
You want to make 2 builds for 2.5k?
I dont get the first build, What are you getting from a $300 truck kit? Whats Pei Pei Scooter? why use a VESC6?
Had a SK8 6364 245Kv that blew up my 4.12 vesc from Vanda electronics. Also my lipo cells died so I started building the cheapest 12S li-ion I could. $350 for 12S7P 25R with charger and 80A BMS 750Wh.
Note: that’s BMS would actually go into the 12S 30Q and the 25R will be charge only. If I can get 30Q
Yeah I was trying to edit my post in a way that made sense to add that the vesc 6 plus are for the FunWheels and I would easily be able to take them out for powering whatever else.
So I would have a street board a AT board and 2 FunWheels. Probably add another $1000+ to this I can handle it.
I would add 2 or 3 more builds to this list.
Look at some current/recent boards. No one uses 25r anymore
I’ve been lurking on battery threads long enough to know I should have gone 30Q I just wanted cheap and high discharge. 30Q is next for that reason.
Why am I thinking about this like it’s a current build in progress? Apologies for my massive retardation. Back to dream inheritance scenario.
I have only spent about $700 so far on things I have: (vx1 Remote was gift) battery, two TB 6374, 1 FOCBOX two Janux ESX8™ mounts 40t pulleys.
I wasted about $380 on my Turnigy skateboard conversion kit. Motor still works unsensored vesc needs repair. One 6S lipo still good. Mount rekt.
The only thing I would keep there is the remote, motors,focbox. What battery do you have there?
Does flipsky sell additional vx-1 receivers so I could pair the remote to different boards?
@moon the only battery I have is the 12S7P 25R in progress. All the other parts are in a box. I got most of this stuff recently. Had to order an additional 36 cells from nkon because 4P would have sucked.
Especially because I went from planning a single TB 6374 to dual 6374
The Janux mounts are going to be for the 6355 motors from @KaramQ I have my good old 50cal I’d like to put them on.
I’m kind of lost now lol.
2500 will build you a fantastic esk8. Really good if you research it correctly and don’t waste any funds. Stick to tried and tested components with a good deck and enclosure combo.
Plan of action.
1st. Look at what you want from the build by that I mean what type of board do you want?
2nd. Buy the deck and the enclosure that fits the first choice.
3rd. What kind of performance do you want?
4th. Get the drive train that will best get you to the 3rd choice.
5th. Build it with a detailed and pictured thread so we can enjoy the process and help.
You seem a little lost my brother.
I was going to DIY the enclosure, but as I said I’m going to wait for the Torqueboards deck with enclosure so that can be taken care of.
Right now I’m buying as many good parts used as I can. To allow my money to go farther, or faster I guess.
I have lot of time to plan… And make mistakes but hopefully correct them.
