Correct! The dev would need to update his code as the firmware changes because the communication changes a bit over different firmware versions.
Can you clarify how you specify the # of motors used in Xmatic?
I have noticed some folks who have 2 motor setups but the data such as watt-hour is only showing 1 motors worth of data (and not doubling the data like it should).
Also when applying a new mode does it automatically apply to both vescs in a 2 vesc setup?
settings ā data ā ādouble data for dual configā
I think it just doubles the data read from the vesc itās connected to. but iād be happy to be wrong and have it get both like metr does.
Yes I believe that is correct. But does enabling that button also ensure that when a new mode is applied via the app that it applies it to both VESCs?
I donāt think that button would have anythign to do with it based on itās name.
i canāt confirm anything else on the modes. have to wait for someone else. or just test it yourself.
I did just verify that applying a mode only applies the setting to the MASTER VESC and not the SLAVE VESC. I see that you have to check CAN BUS FWD and then reapply the mode to the SLAVE VESC @Twan do you have a fix for this? It would be nice if it just automatically applied the settings to the Master and Slave. This is how Ackmaniacās ESC Monitor works on Android.
Also I just observed that when applying the mode to the SLAVE VESC, that motor now spins in reverse. WTF? @Twan, I would appreciate a response. Customers paid for this app, and itās not doing what itās supposed to do.
can anyone tell me what the latest version of this tool is?
and can peeps use this app on multiple boards?
I go and hit the icon of the board iām going to ride and it defaults to something elseā¦
does this app base itās setting on a particular BLE module ID?
1.70. is what I see in the app store. and what I have.
yes. using the āgarageā menu in the upper left of the home screen.
whatās that mean?
I think for each board in the garage you get a separate set of records and settings, and included in the settings is which BLE device youāve selected. but I think if you wanted you could have two āboardsā in the garage using the same device.
no⦠Iād like the app to know by which BLE ID which board I have set up⦠that Iām going to rideā¦
does that make sense?
how I make update?
I am fucking estUUpid on all apple stuffs⦠I have 1.6~something
Holy shitzabobs I just noticed @kook and @fessyfoo are different people , your avatars are so similar at a glance.
It wonāt auto switch based on what it finds. It wonāt create a new profile if you just select a new BLE device.
you have to use the garage menu in the upper left of the home screen. to switch profiles to a new board. ti will remember which BLE device went with that board.
open app store, find xmatic app. it should say update. if it says āopenā. then it thinks itās up to date.
gracias amigo⦠Iāll try againā¦
but in all honesty, iām already at my wits end on this appā¦
maybe Iām over complicating it⦠others seem to like itā¦
but the author iz like a ghost and @sofu is making the stormcore app so, so much more attractiveā¦
this app had potential⦠but Iāll prolly not be investing much more time chasing outdated appsā¦
itās prolly my fault⦠but IDK make an app intuitive and easy or make it a dinosaurā¦
@Twan already has my bux 5
yeah. itās a good app. but it took me a minute to get it. woudl take seconds if someone just walked you through it.
I didnāt understand the garage menu even existed for a long time.
and the other long term stats window is hidden by a button in the upper right I didnāt realize it was there for a long time.
then thereās the faults window. which is a button in the top left of the stats view.
and the log is click the version number in the stats view.
he actually does doc a bunch of it pretty well in FAQ and Setup.
I like that it does wh/mi per trip. and has a long term odometer.
anyhow⦠blah. everyoneās got their preferences. this thing makes HM-10s useful again.
even the horrible VECS app has loggingā¦
I donāt use it much⦠always enabled now you showed me the magic⦠but if iām curious I can look it upā¦
i know itās prolly user error⦠but I have boards with much different character⦠when I select that board in the GAYrage⦠it should give me that board⦠even better if the app knew buy the BLE IDā¦
but water under the bridge⦠maybe youze could help me out next time we sk8!
thank you
yeah, itās not a full on ride logger. [ when I mentioned logs I meant the app logs. just for clarity. ]
but the ride stats it keeps are useful summaries of your usage.
I bought this app on a whim⦠I wanted legit stats⦠on the unity on original FW I can get enuff info for meā¦
on the VESC FW eventho I hate the app⦠it doesnāt scare me anymore⦠itās still one of the most unwieldy apps Iāve ever used⦠it was like clown A said⦠yeah letās put that shit in⦠and clown B did itā¦
make an app you set it up⦠it CANNOT make changes to ESC⦠you supply basic info and it spits back data on command and is smart enuff to know what device it is hooked up toā¦
iz dat 2 much to ask?
yes.
write the app you want to see. or leave the poor souls alone apps are hell. especially if your specialty is ESC hardware .
