Yes, has tube and screws fully in. Not inflated, but did try again inflated with the same results.
Can’t take it out for a spin yet, but every tire I’ve tried that’s had a noticeable imbalance was hard to control around ~35kmh. Just spinning with my hand causes the board to shake.
Nah, think its time to buy BRP airless wheels. I gave up on using imbalanced tires + weights awhile ago. Balance + grip is the only thing I really care about.
I have noticed that tubes can bunch a bit inside the tire. Might have to try a bit harder to not get it to bunch, like maybe bunch away from the stern side. Or try not to get bunching at all. So something additional to check.
You gotta inflate them. Put some superlube all around on the bead before you put the tire on the rim. This will help the bead seat better. Inflate to 60psi.
xcell rs tires were unobtainium for a long time, so people started trying out different tires. The Meepos are softer than the v1, probably still softer than the v2. The v1 were very hard and kind of unpleasant to ride for anything other than racing.
From what I have seen, the v2 are better balanced than the v1 xcell rs tires.
It’s pretty unlikely that you got 4 awful balance xcell rs v2, unless you got super unlucky and the batch is bad. There is probably something you can do in setup to make the balance quite good.
I’ll throw on some weights and see if it at least balances them. Not the cheapest tires, so I don’t want to give up on them, but at the end of the day, I’m not going to force myself to use them.
the tube pushes on the tape on the rim yah. but it’s not a problem. tube also pushes against the edge of the bead to rim transition which is probably harsher. Just in case i’m not communicating it clearly the idea is the tape thickens up the hub so that any space between the hub and the edge of the tire is taken up to keep things centered as it’s getting inflated.
Some hubs taper from a smaller diameter to a larger one as they push out to help with that centering. Others have a slightly angled lip to do similar.
We did see the failed centering of some of the early v1s on some hubs so that’s why i’m pointing it out.
Matt Hover seemed pretty obsessed with good balance of the RS tires, when designing them. it was one of the feature claims. So it seems odd you’re such an obvious imbalance.
You shouldn’t need weights to balance these. Until you share more photos and videos of your setup, there isn’t much we can do to point you in the right direction.
Honestly, this is kinda strange. I agree with you, the balance doesn’t look good. I’d try to remount them with different inner tubes. Use 150mm tubes, not 175mm, to make sure there is no bunching.
If that doesn’t work, I’d return them to xcell. You shouldn’t need to use that many balancing weights on tires.
