Want to trade 2x brand new custom wire length 190kv 6374 unsealed maytechs for 2x new 6374 190kv sealed maytechs plus a little cash.
Let me know what you have.
I doubt this is still up being that I’m like a year later. what’s your shaft size?
Extra large?
8mm.
as soon as I sent that I went wait a min. Decided to let it slide. … damn. All my motors are eight mm and I need ten for the drives I just picked up
What drives?
I contacted 3D servisas to see if I could swap the motor gear for an 8mm but he said that it’s the first generation drive and he hasn’t produced parts in over a year for it so I’m stuck buying 10mm motors.
It’s a v2 version, so I guess second gen?
Yup the motors need to be a 10mm shaft, pretty sure I mentioned this
APS
Saite
I think some Maytech are 10mm(nipples may make the 6384 version too long)
Conceivably you could use a 1mm thick metal tube with a slot cut in it matching the keyway slot and use a slightly taller key as a shin, that would be kind of overkill tho
Electricboardsolutions sells a 6880 motor with a 10mm axle.
@Ace i might have two 6374 170kV motors for you
10mm shaft from APS. Not used too much, battle hardened bell as well as sensors covered with epoxy.
Thanks guys. I was planning on buying a set of new maytech for them but it doesn’t hurt to ask around!
@Andy87 My parts superstore!
what do think you’d want for them? And how blasphemous do you think shipping would be?
@Andy87 has a reputation for taking it easy on his esk8 stuff, here’s a motor I bought recently from him, rated 9/10 condition
That’s uh, that’s a brake disc?
omg that quote… i’m using it.
This time I better advertise the motors as „like new“ ![]()
@Ace as you know I can’t post pictures of them as I’m on a travel, but I wanted to put them up for sale with some other stuff when I’m back, so thought I better mention it now before you buy something else and than cry in two weeks
jk
I thought about 85$ per motor. Shipping shouldn’t be more than 30$ for all.
I can wait two weeks! I knew there was a reason my motors weren’t selling🤣
I will pm you when I’m back. You will get first dips on all parts
Lol I seem to be in the habit of buying whole lots of parts recently.
