I will cram whatever you order into the cheapest flatrate box and ship it to you that way. Shipping cost is whatever that box costs. Domestic orders are priority.
I keep this post updated so unless it’s marked sold, it’s still available (no matter how old the post is).
Note: there is some surface rust on most all of the bolts in this listing. This is because I replaced all of the stainless steel hardware that came with these parts with grade 12.9 steel bolts to avoid stripping threads or rounding heads. The rust is not representative of harsh conditions, rather the lack of stainless steel hardware in a moist storage climate.
$50: Torqueboards 15mm wide 36t kegel pulleys. One used, one new.
$80: v6 Torqueboards dual motor mount kit. The crossbars you might see in the corner of the photo have already been sold & are not included. One mount has been used, The other one is brand new.
SOLD & SHIPPED $10 This used mini torqueboards remote w/ reciever
SOLD & SHIPPED $220: Surfrodz RKP 200mm 45deg baseplates. Comes with 90mm and 80mm shoulder bolts. Also comes with Boardnamics axles that let you use these like traditional trucks with 8mm axles and no shoulder bolts. Also includes pressfit mounts and carbon fiber motor mounts from moon + crossbars to brace the motor mounts. All of this is super high quality and is brand new minus a test assembly.
BOTH SOLD & SHIPPED $20/ $15 pair: (16T (top)(torqueboards, new) )(15T(bottom)(3dservisas, used)) 15mm wide pulleys. Lip on one of the 15T pulleys is chewed up, still functional.
SOLD & SHIPPED $200: Silver Bergmeister wheels with 60T moon alimunum pulleys, 4 spare tubes + 2 spare tires. Used a couple of times
SOLD & SHIPPED $80: Torqueboards 110mm 74a wheels, brand new
SOLD & SHIPPED $120 pair: Flipsky 190kv 6374 motors 8mm shaft, used
SOLD & SHIPPED $140 pair Maytech 6354 waterproof 170kv 8mm shaft. One used a couple of times, other is new.
SOLD & SHIPPED $40: 10s enertion charger. Used.
SOLD & SHIPPED $40: Torqueboards brand 12s charger.
SOLD & SHIPPED $20 Used Flipsky vx1 remote w/ receiver
SOLD & SHIPPED $45 fingerless small flatland 3d slide gloves, used a few times.
SOLD & SHIPPED $15 4.12 Torqueboards vesc. Solid condidion besides my awful soldering and (???) wire length.
GONE Free with highest $ order: belts from 405-445
GONE and assorted wiring parts
GONE Free with any order to whoever asks first: Focbox unity, dead. There was a cold solder joint from my Hellen Keller tier soldering which vibrated around under load and caused a spark. Can probably be fixed, but as a disclaimer this should be used by noone.
