Clearing some stuff off the shelf. All very lightly used. Belts are all new
Prices include the cheapest USPS shipping (within US 48)
2̶x̶ ̶M̶a̶k̶e̶r̶ ̶X̶ ̶M̶i̶n̶i̶ ̶F̶o̶c̶ ̶P̶l̶u̶s̶ sold
-briefly used on a board set with TBDDs, drives didn’t last so these are getting parted out. Assume you will need to buy proper connectors, will include can bus
$130 for both (USD): with custom CNCd heat sink
2x Zesc ESC v6c
-Was going to use these in a small odd project but they never left the bench, one side was bricked on an update. These have the 3D printed baseplate. Thread
$75 for both (USD):
̶M̶a̶y̶t̶e̶c̶h̶ ̶H̶W̶4̶ ̶d̶u̶a̶l̶ sold
-not much to say, has never been used off the bench. both sides work fine
$70 (USD):
Bestech HCX-D223V1
-this was pulled from an actually pretty decent 10s3p battery from DHgate, it was replaced with something smaller. Was tested and working without issues. Seller on Dhgate says it is the 80 version. Will include power switch
$30 (USD):
HTD5M 15mm Belts of all sizes
-new belts of different sizes: 255, 265, 275, 285, 330, 340, 350, 355, 420
$12 per pair (USD):
H̶A̶Y̶A̶ ̶D̶e̶c̶k̶,̶ ̶n̶e̶w̶ sold
-Bought this for a AT build but never happened. Still want to build an AT board but it’ll have a battery bigger than the 12s4p that will fit in this. Never used or mounted, been in the box since I bought it. It’s a beautiful deck but needs the right project
$130:
A̶B̶S̶ ̶E̶n̶c̶l̶o̶s̶u̶r̶e̶s̶ sold
-New psychotiller Evo 40 enclosure. I personally didn’t like it, so never got used or mounted. If you buy it I can throw in a slightly mis-molded shortboard enclosure good for 10s3p. Was my first vacuum form attempt so has some webbing, otherwise very useable.
$35 shipped:
