GT2B is rechargeable and mini is on AA batteries. Other than that, im not really sure what the difference is. Ended up using the GT2B in the end, so guess I like it more Maybe it’s the shape.
Idk how you guys use trigger remotes with gloves. I can never brake properly, or I just brake by mistake. Also with the mini remote I can’t even get the throttle all the way dow. (Again with gloves)
I just gotta stick with the puck or the vx1. Want to try the maytech remote but idk still hear it cuts out in high traffic areas and unfortunately that’s everywhere in LA :/. Guess we are waiting for OSSR
You could be the first in line still haven’t got a reply from him…
However dimensions probably isn’t right… The battery is a bit bigger than it could be, due to the nickel being folded a bit off-center and wires sticking a bit out on the side.
How much space how you got working with?
The battery is approximately 30cm x 14cm x 5,5cm + BMS. Would of course confirm the exact size once everything most likely will be taken apart
