Used my board yesterday but a belt snapped so did a long walk of shame home but motors was disconnected. Opened the enclosure and there was no water inside (always do this) so cleaned of the rest of the board.
Today I put it back together and charged the battery (12s4p 20700b full for the first time and now I suddenly get this error when turning on my unity
Just a FYI plugged in a 4cell lipo that was at 14.xx volts and it shows up as 21v.
Bumped the board on my way home so might be hardware related to if lets say a resistor came lose but impossible to say without some knowing of the circuits
Yeah seems like one of the resistors on the voltage divider to measure voltage is somehow changed? Really strange I’d take off the silicone and wipe down the PCB make sure it’s all clean.
Will do. You don’t have any info on what resistors are used for voltage dividing and what values they should be? Could check them all to see if they are correct after cleaning
Good to hear that I’m not alone with this idea
Was nice and clean but cleaned it with IPA but still no change Was considering that a solder is lost but then it should not show any voltage at all. Might need to check all resistors one by one and hope to find one out of spec.
thank you!!! Seems like R23 is at 4mohm
What resistors are these? Just messed with smd components a few times. Will se if my local supplier got in stock
Measured a bunch of times now and its 12mohm so definitely broken. Higher Ohm should mean that the MCU sees less volts if I’m not mistaken (rookie on this lol) so really odd that it shows 61v but might be that its so far out of spec that the MCU goes nuts. Will pick up a new resistor tomorrow they ‘‘only’’ had 9559 in stock at my local electronics shop so should be all good lol. Will report back here what happens when its swapped will do it first thing when I get home tomorrow.
Thank you all for the help so far much appreciated!
