Looking for pulleys for berg hubs less than 60 teeth but more than 40.
I have a .stl for bolt on 60T (with or without support bearing seat)
What trucks does it work with? I know the kahuna and BD are different axle length
The version with no bearing seat uses standard axles and can go over any hanger, the bearing supported one is meant for TB218 but it should work for any axle longer than 45mm
If I’m interpreting what I’ve researched so far correctly all you need to run TB218 pulleys on a evolve truck is a washer between the bearing in the pulley or mod the file.
I’m slightly confused, what parts do you plan to use?
Berg hubs on Vereal dkp/evolve copies.
This is what I’m basing that assumption on: NEW: 49T and 55T press-fit Bergmeister pulley —> fully compatible with TB218 and Evolve GT trucks
I think @longhairedboy may have had a stock of these?
They are specifically for kahuna trucks and have large axle spacing
