Top of the day boys n gals,
We got in stock (in very limited quantities!!!) our new press-fit pulleys
Each pulley is CNC milled out of a solid piece of POM and can be used on both Evolve GT and TB218 trucks. T he pulleys include a bearing(s) that ensure(s) a perfect fit on the truck’s axle.
For the Evolve GT trucks, we use for each pulley:
1pc washer + 2pcs of 16100-ZZ bearings
1pc of 295mm long / 15mm wide / HTD5 timing belt for the 49T pulley (when used with a 15T motor pulley)
1pc of 320mm long / 15mm wide / HTD5 timing belt for the 55T pulley (when used with a 15T motor pulley)
For the TB218 trucks, we use for each pulley:
1pc of 638-ZZ bearing
1pc of 320mm long / 15mm wide / HTD5 timing belt for the 49T pulley (when used with a 15T motor pulley)
1pc of 340mm long / 15mm wide / HTD5 timing belt for the 55T pulley (when used with a 15T motor pulley)
Both bearing types that sit inside the pulley and on the axle share the same outer diameter of 28mm….so they can be easily changed out to swap between TB218 and Evolve GT setups.
The area on the drive pulley where the belt runs on is very wide (22mm) with a single flange. To avoid having the belt move sideways on the Evolve GT setup, we will also include a belt retainer ring (spacer ring) to ensure that the belt is always perfectly aligned.
This retainer ring is not needed on the TB218 setup, because the motor mount itself can be easily adjusted.
The retainer rings in different sizes can also be downloaded here: https://www.thingiverse.com/thing:3855745
(Further .step files for different widths will be added within the next few days)
Package pricing as follows:
Pack A : Evolve GT 49T (dual setup)
2x 49T pulleys + 4x 16100-ZZ bearings + 2x washers + 2x 295mm timing belts
USD: 114,- (incl. shipping and PayPal)
Pack B : Evolve GT 55T(dual setup)
2x 55T pulleys + 4x 16100-ZZ bearings + 2x washers + 2x 320mm timing belts
Pack C : TB218 49T(dual setup)
2x 49T pulleys + 2x 638-ZZ bearings + 2x 320mm timing belts
USD: 110,- (incl. shipping and PayPal)
Pack D : TB218 55T(dual setup)
2x 55T pulleys + 2x 638-ZZ bearings + 2x 340mm timing belts
Special add-on: choose any of the above packages A, B, C or D and you can get Pack E or F for an additional USD 195,- or USD 370,- respectively
Pack E : Aluminum / CNC milled Bergmeister wheel set
4x complete Bergmeister wheels (choose your color: black, silver, orange, purple, blue, red)
4x Extra inner tubes
2x Extra outer tires
USD: 198,- (incl. shipping and PayPal)
Pack F : Aluminum / CNC milled DOUBLE Bergmeister wheel set
8x complete Bergmeister wheels (choose your color: black, silver, orange, purple, blue, red)
8x Extra inner tubes
4x Extra outer tires
USD: 375,- (incl. shipping and PayPal)
All components are in stock and we try to send out orders as soon as possible. But please give us up to 6 working days to have everything sent out. If you are interested, send us an email to hello@wertrimo.com with the following information:
First name + last name
Postal / shipping address
Phone number
Paypal email / account
Preferred package and quantity
Preferred color for the Bergmeister wheel (in case you also chose Pack E or F )
We will then send you a Paypal payment request. This offer is strictly on first come / first serve basis (on money received).
If you have any questions, let us know and we would be happy to answer.
Best regards
Jeff and Timo
