You can shim the mounts by cutting strips of an aluminum can and putting them around the truck. You’ll probably have to clamp it, unclamp and add another shim since they’ll crush little.
you could try using a drill with a decent bit and a bench vise to make the bolt slots longer and move the motor closer to the hanger, then chop some meat off the enclosure side.
I give you presents and yet you just
COMPLAINCOMPLAINCOMPLAIN YAYAYA
No kidding. when I had them on the falcon they only worked with like 1" of riser. Not sure if thats an option for you but I can bring you risers this weekend.
As far as clamping them down, they worked with my wider cast calibers but needed to be clamped down until there was no gap at the clamp portion
hmmm and shimming them on the flat spots of the trucks? like just inserting some steel?
if you want your $ back just lemme know. Ill put em up for sale with a disclaimer
what about using your trucks as part of the battery wires such that the immense heat generated expands the metal enough to where the the clamps fit properly? Would make for really easy assembly and disassembly when cool
It’s a shame those mounts can seemingly only be found at Mboard. Usually I can find anything from Mboards on alibaba. Might take some more hunting. Ran across these though
