I’m rebuilding my board after a long hiatus and am sick of the two thin 8 inch wheels on the front of my board. I have the wide 9” tires and matrix 2 trucks on the rear powering the thing so I’d only need 1 set of trucks and 2 hubs/tires.
I’d also love a case/box box for my dual single FOCbox, currently using a pencil case from target.
I have an apex ESC case available.
Would that fit dual FOCbox? And would the rockstar 2 hubs fits 9” tires?
I’ve got a spare matrix 2 truck I can sell you along with a few lightly used 9" offroad tires and new tubes. Also have 9" road tires if you’re hitting the streets often.
Rockstar 2 won’t fit 9" hubs. Only MBS hubs that will do that are fivestars or the new metal ones (XL hubs)
YES PLEASE
I MAY have 2 fivestars laying around too. No promises though. Will look after work.
No promises required, but would make my life much easier if so! Rather not have to put of the states.
The mounting holes are for focbox unity or Stormcore. Dual focboxes may fit but the mounting holes wouldn’t like up. You could drill your own. If you send me the dimensions of the focboxes I could check.
The rockstar 2 hubs I have will not fit 9in.
Inside space of the ESC box is about 150mm x 100mm
Is the base of it aluminum for a heat sink?
I have some Boardnamics 310 Split Angle Channel Trucks, MBS fivestar hubs and some 9" tires for sale.
Edit… I’ll have to check on the MBS fivestar hubs. Can’t remember if I still have them.
Please do! I’d love the 5 stars, and are the tires off road tires or steet?
