How do you like your E-Toxx Adjustable Angled Risers now? Looks like you’ve had a couple years to earn the experience of a review.
Do you think this etoxx design of eliminating the kingpin bushings makes a difference at all?
Did you 3D print that baseplate spacer thing that your using in between the deck and riser or did you buy that?
Also are you also using that adjustable riser plate in your front trucks too?
What angle do you have yours at? Looks like the furthest you can adjust the rear?
How are you enjoying those SKP 3d printed angled baseplates? Does not look like he’s still selling them.
[quote=“jpaulglobal, post:41, topic:66216, full:true”]
There great. Being able to dial in angles for high speed or more turn is fun.
Do you think this etoxx design of eliminating the kingpin bushings makes a difference at all? Seems solid. I was using a 3ds hanger which was not made for it but it had a tiny bit of side to side. Wasn’t too noticeable
Did you 3D print that baseplate spacer thing that your using in between the deck and riser or did you buy that? It’s just the mbs rubber plate thingy
Also are you also using that adjustable riser plate in your front trucks too? Yes on both
[/quote] I had rear close to zero on a 35/35 deck fronts were at 40-45 I think
They’re good. Haven’t had any issues with them at all.
