Looking for a HolyPro / HS11 35 stateside. Ideally with the cable cutouts routed (the “electric” version).
I’d like to eventually build a dedicated eMTB with MBS trucks and hubs, but who knows when MBS US will restock.
If anyone has some parts lying around, let me know!
Thanks
Nacho
June 4, 2021, 12:42am
2
I know you said state side but maybe
I saw that one - very tempting. But at 90kg, i don’t think the 15ply would do it
Nacho
June 4, 2021, 1:07am
4
Yeah I just read that my bad
hell of a deal though
I’ll keep my eyes open
How much is a used Holy pro deck worth?
This one went for ~$160 USD.
$212
[UK] WTS Trampa Deck, Eboosted SS Enclosure, Sabre Blades
Trampa HS11 14 PLY Deck
HS11 deck, unused, grip tape removed. Decided to buy for a project (hence the Eboosted enclosure) however the weather is so bad in the UK, I have decided to go for a trampa build with their deck with cable grooves.
Looking for £150
[20210124_132637]
Eboosted SS Enclosure, see above for reasoning for sale.
£100
[20210124_132702]
Sabre Dynamics Deck Wings
Not actively looking to sel…
$255
Yes, I bought it direct from Trampa in May 2019. I know what you mean, I was a bit confused to see that the deck has rounded cutouts in the centre of the board, and an asymmetrical nose and tail. My photo is misleading, I will add another one now. Thanks for pointing it out!
In my receipt, the details state:
35º HS11 Brake Board
16ply 35º HS11 Deck - Stiff
Which leads me to believe that the HS11 and HS11 Brake deck may be different items. I think the asymmetrical nose and tail in the Brake D…
$270
I am selling the following because this board is to big and where I live they are quite illegal and the way it is now it turns to many heads… so I want to build a street carver.
2 x Vertigo Truck - 12mm HOLLOW Axles with Black CNC’d Baseplate & Steel Kingpin TRAMPA Spring SOLD)Trucks. : SILVER Anodised with Black logo INFINITY Baseplate. : NICKLE PLATED Kingpin. : Nickle Plated SILVER Springs. : RED DAMPA’s - 80a Stiff Steering. : M5x25mm Truck Bolt kit - 12-16ply decks
4 x CUSTOM 8 inch SUPER…
New is $250, not sure why people were selling higher - maybe exchange rate
https://trampaboards.com/1073-35-holypro-electric-mountainboard-deck-with-special-cnc-channel-for-housing-cables--p-27498.html
God that site is heinous. The UI is abysmal.
It’s a carver deck tho It’s smaller than the HS-11 for example
I have the same one as the one showed without the holes tho and 16ply 120kg it’s pretty much becomes a flat deck that is very flexyble lmao Trampa sells some carbon fiber dodads that makes the deck a bit stiffer tho so it could be worth it
Sorry man I’m sleep deprived atm.
I have a carver deck wich is the same as the one on electricboardsolutions, it’s a 16ply rated for 100-110 ish kg. I’m 120kg and when I get on it the curved deck becomes flat ish.
BUT if you wanted to make the 15ply on EBS stiffer Trampa sells some small carbon fiber plates that you epoxy under your deck so it’s less springy and ends up stiffer pretty much making it a 16ply
I hope it’s better like that I’m on my way to sleep now
