I’m wanting to upgrade certain parts of my board as I ride it more and there are a couple things I would like to change about it. I am proposing some trades for some of the parts, as well as cash on top from me.
Apex air trucks- would like to trade for a set of matrix 2s I have.
-Set would be great, but I would take a single too
-preferably with mounts if a set.
MBS F5 bindings-would be great to trade these for aliexpress bindings I have plus some cash
-don’t care about condition too much, also interested in heel straps, could be MBS or trampa.
Fivestar hubs- or any that could fit 9 inch tires.
Don’t care about condition. If you have tires and tubes too, that would be amazing.
Rockstar 2 compatible 72t pulleys
Maybe 66t if somebody has them.
Preferably metal.
Please hit me up if you have something similar to what’s listed here
Nope, 8in tires usually needs 3.8in lip and 9in tires need 4in lip.
Edit: A comparison would be using 8mm axle with a 12mm bearing. It fits and can work, but that doesn’t mean it will work properly and not cause problems down the line.
If you wanna run 9in tires. Hubba hubs with a 3d print lip is pretty good and cheap, a set of Hubba hubs is about 70 bucks pre shipping. They’re wide enough that you can run most normal tires.
Edit: Hubba hubs also takes up the same amount of axle space as regular MBS Rockstar II hubs.
You can do that, idk anyone that has the files tho. Plus the Rockstar II are pretty narrow, they’re mostly for 6-8in tires so you would also need to find the widener files.
I’ll check and see if I have all the wheel halves but I have a set of Fivestars that were dyed a funky bronze-ish color. If I have all the pieces you can have em for whatever shipping is. I’ll post pics later. They’re a weird color
Anybody have 72t pulleys??
I really need a pair of real ones bc the 3dp ones aren’t symmetrical and have lots of problems. Metal preferable but I would take the MBS ones.
