These pulleys are from a lacroix nazare. (not lonestar ). so 12s6p 20700b against 6389 motors maybe 800km use.
the teeth wore out to little blades. I’m guessing it’s just aluminum. but wondering if that seems normal.
and also dropping here for reference.
tipsy
June 20, 2020, 7:21pm
2
I thought they use titanium…
awesome man, you definitely got your money’s worth out of that one
how many belts did it take got get that much wear?
not stock. that’s an upsell.
I got it used. so I don’t know for sure how much abuse it took. looked like stock belts on it when I got it.
Preety normal with aluminum pulleys
RyEnd
June 20, 2020, 8:04pm
7
Yeah, get some steel ones if you don’t want to fork over for titanium.
A13XR3
June 20, 2020, 8:59pm
8
Yeah aluminum motor pulleys will look like that eventually for sure, and I’ve seen plastic wheel pulleys look the same too.
Steel motor pulley over aluminum always.
We call that a shank, Looks painful!
dani
June 20, 2020, 9:10pm
10
Same thing here, guess it’s time
after less than 50km my alu ones looked the same on my trampa Alu is crap for this.
You have to imagine how much friction you’re applying to each pulley. The belts we use aren’t the softest lol aluminum just isn’t up to this application. I’m surprised that’s the result though! Did you have a belt snap on you ?
No snapped belts. but I got this board used, so… who knows.
b264
June 20, 2020, 10:40pm
14
Yeah, this is exactly why a lot of us recommend steel (or titanium) motor pulleys and aluminum wheel pulleys.
Keep plastic, POM, ABS, nylon away from your wheel pulleys and keep aluminum away from your motor pulleys
