Its all custom on the hubs?
And found them cheaper, buy two pieces max at a time or the shipping sky rocket
Stretched 155x50, stretched 6x2, stretched 5x1 have not tested the 5x1
155x50 has a nice short sidewall and tread flattens the best of all pnumatic
Very soft and grippy at 60a
Welp, 2020 looks to be the year of grip and fat ass back ends.
How wide are we going again?!
Whats the distance from outer bearing to outer bearing? Whats the minimum axle lenght (minus the treaded part) necessary to mount this hub adaptation?
Thinking about this a bit more, the outer hoop loses its support (the spokes). Surely this is a concern? Would it only be a recommended mod for Megastars, since the hoop is aluminium?
I thought it was still connected sorta via the bolts, the spokes are just directly behind the hub rather than located inside
Possibly somebody could model the spokes too for the spacer and the original can stay in the hub?
Potentially, but I wouldn’t necessarily go jumping with them.
I would. For science.
With it you will need than more space on the truck as well.
Not if it doesn’t carry a bearing.
That might work for trampa trucks, but the Matrix2 shaft is way shorter. Even without bearing the hole would hit the hanger.
Ok if it would hang over the shaft outside facing that would work. Not sure if it’s possible to tighten the nut than thou
Megastars are available in 8 and 9, with and without offset. The offset versions allow more space for bigger motors.
Yeah, but they also not the cheapest and for people who already have superstar hubs that would be a good option.
By the way, @Trampa when you think your plastic 9“ hubs will be available for sale?
I only order the outer alloy rims (already got stars/spokes) … a tiny little bit cheaper ^^ haha
Edit : @Pedrodemio, I will take photo today
Thanks for this. Any chance you know how much offset do the offset megastars have?
Also are the 9" ones the same width as the 8" ones?
Perfect. When are they available?
That would be a huge block of aluminum they would need to be cncd out off
Save money, make from pom. Lol
