Few people are choosing calibers over stronger options nowadays, and those other options usually have mounts by the same vendor, be it 3dservisas, boardnamics, torqueboards, etc.
For the record your mounts are superior to theirs, but ofc the price is higher too.
Just make some trucks that are better than the rest, and the demand will come
(Or innovate with the outwards facing motor idea I shared! )
You were going to share that outward facing motor solution with us. Have you made it now? Think I have seen it on the old forum once, with stand off screws between mount and motor.
I’m making 74mm c-c for caliber, TB218, fatboy and reverse mounting on Sr tkp. These will replace current 80mm ones. Then 100mm version spacially for rearward mounts. @Bboy235 Will that work for you or is there something about the 80mm you need?
74 center to center ±4mm adjustability. On paper 80 vs 74cc might seem insignificant, but together with the tweaks done it gives significant more clearance towards both deck and battery enclosure:
Thanks for the support @rusins, your positive attitude is very much appreciated I expect to have new stock in 3 weeks. I understand if that is too long time to wait What trucks will you be using for that build?
Yours, if they’re available Otherwise e-calibers; it’s for my little brother, who won’t be going fast. 3 weeks is good; need him to learn to ride analogue first.
Trucks will not be available by that time, but I will make sure your brother gets the mounts as soon as they are available. Always great to learn analogue first. Often I find myself preferring the simplicity of just going out pushing around after a busy day
