Who is using Akhlut's surfrodz axles? (Axle issues)
Did it, I noticed it was wiggling ever so slightly side to side so I kept rotating and pulling one side to the other. Looks like the threads got caught up in the end of the hanger.
For sure bent. I cant tell where since I don’t have a straight edge but I think on one or both sides of the mount plate.
Going to need some different mounts and hanger.
Hey I got Xtla press fit adaptors not the mounts just the adaptors I could throw them your way if you cover shipping
Thanks for the offer, but I don’t think they will fit 175 or 150mm hangers right now and I think 200mm might be too long for what I want. I’m likely going to replace everything in the drivetrain. Just thinking what I will end up doing atm.
Sucks to see guys.
This is exactly what happened to a set of SR rkp and their bolts that I have. I came to the conclusion that I must have hit a bump aggressively and caused enough torque/pressure to cause a small cross thread. Those threads looks identical to what I found in mine.
However, I’ve hit some massive bumps in sidewalks with my SR tkp with their bolts, bolts come out smooth everytime. My two cents :kissing_closed_eyes:
Guess this is why material choice is so important
FUCK
I imagine this would be my reaction as well haha
I have like 2 sets on-hand. I’ll have to figure out how to get replacements out. I sent @sender and @mmaner everything else I had
@thermalchild I’ll shoot you a new set today or tomorrow. What size hanger was it?
@Saturn_Corp ill send you another set.
He lives! Sah dude. I was running the 176 rodz.
RKP
lemmie see if I have a hanger lying around.
I’m just happy everyone is OK. Parts fail and can be replaced. People can’t be.
And yeah, I’ve been away for a bit. Priorities had to shift with the lockdown. This summer has been fucked. ESK8 is still on my mind, just not occupying as many compute cycles these days.
Yeah man, I’m glad I was able to walk off the board, could’ve def been worse. Still not sure of the exact cause of it though. That’s why I wanted to check in on people rocking these.
Did you wake up to my email?
Thanks for chiming in Matt!
If your cnc is open for some custom motor plates manny and I both have some needs for that
You going custom or need some for these mounts?
@akhlut is sending me some files and I am getting some for these cut at a cnc I have locally.
Glad to see your return…
My man! Hells yeah, @moon hooked me up with a set and they’ve been fine. Would def love some mounts that are bit longer though. Let me know def interested.
I’m gonna need something for tkp, have tiller plates now
Manny could use something longer than the moon plates to clear the tail of the Hummie
Took the hanger over to @bwahl602 and he was able to drill it out EZ. Received the new set from @mmaner yesterday. Will try and get the hummie back up and running this weekend.
