Where to buy 10mm speed rings?
Hey guys I’m in need of 10mm speed rings. Need something that has a 12mm OD and a 10mm ID so it only pushes up against the inner part of the bearing rather than the full thing like a washer does since a washer has a bigger OD.
Maybe @mmaner would know
I think I’ve got a bunch. I’ll check when I get home. Could drop a few in an envelope if I’ve got em
You da man , lmk dawg. I’m lost trying to find them :sweat_smile: @KfromtheBay
I’m looking myself. I have sample en route but nothing concrete yet.
It’s like trying to find a needle in a haystack haha . Just rather my wheels spin more than 3 times around before stopping :grin: @mmaner
On second thought. What I have may be closer to 15-16mm OD. will still double check after work in a couple hours
Yeah I have those but they tend to push against my inner part of the bearing causing the resistance to be fairly high. Which sucks haha. All these 8mm speed rings but no 10mm
This is what I’ve found on Amazon. Not sure where else to find them.
Evolve sells em! Overpriced but fast shipping and exactly what you need
I think these might be the closest thing to a regular speed ring honestly. @Mobutusan
Reallllyyyy @KaramQ
I think if you use 10mm ID shim as search terms Would yield better results than washer or speed rings. Ymmv
Yeah but it has other stuff with it. It’s like a hardware set with 4 of those speed washers. I’m guessing you don’t need many so I think that would be a decent deal for you. Unless you need a lot lol
Yeahhh it does such paying 10$ plus shipping for 4 speed rings blahhhh @KaramQ
Yeah, these are also good for fine tuning spacing on Surf Rodz axles and they come on packs of 50 for $6-8, so you don’t have keep track of every last one as if they were made of gold…or made by Evole. :smirk:
#Aliexpress US $1.70 15%OFF | 100 Pcs Thickness 0.3mm Flat Washer Ultrathin Gasket Thin Shim Washer Stainless Steel 304 M3 M4 M5 M6 M8 M10 M12 M14 M16 M18
These work? Can someone mic on out for me? I’ll order a 1000 from dickkyho on my next order.
Mic? @kevingraehl
micrometer
a tool as a noun
measure as a verb
Kooky kook what you doing here, we know you run 4mm axels. @kook
Nope… I have a micrometer, I mic them all out just to be sure…
