That’s what I typically use, I’m waiting in a stainless 2mm tall speed ring for 10mm and 12mm axles. I have a massive amount of 8mm stainless speed rings already.
https://www.gobilda.com/stainless-steel-shims/
where i got mine for the matrix 2s i have sitting
@kevingraehl that’s a great idea, using the bolt like that. I always just use my thumb on a file. Maybe using the bolt like that on griptape I can really thin down washers
Here: https://www.mcmaster.com/91437A457
Now you can stop the search. Enjoy!
Sadly too big! That is 12mm ID @NullBlox
FML, well I tried…
Im would like to think they have the ID you need or no?
I use those for my Matrix II Trucks.
I’ll check brotha ! @NullBlox
@kadeanderson is this it?
Wow, the 8mm version of that looks awesome, going to try them. Thanks for that link
edit: THESE ARE TOO SMALL, DON’T BUY THEM
they are like 7.94mm and do not fit on axles
@b264 yes. I learnt from McMaster Carr that it’s normal. Washers are stated with a full number but are usually very slightly under if you do no go for a custom order. Machinery isn’t precisely calibrated to the micron on mass production. Sorry, I tried.
Possible you could place a stack in a lathe and remove the wee bit of extra?
Dude you have weird washers in the US. In Europe if you order an 8mm washer you can be assured that it goes on an 8mm shaft.
It’s the USA — they probably don’t even know what a millimeter is, voted for Donald Trump, and bought the newest iPhone.
Sometimes I am embarrassed to say I live here.
This is European 11mm, not those American K00k measurements. But still not the 10 you wanted, and shipping to US is silly for something worth a penny.
Good luck!
10mm is the inside diameter needed
Oopsies. Then these are tiny 7mm.
There are worst things than living in the only region of the Solar system where imperial is used… you should come to California and see the liberal mayhem ![]()
they just created over here ![]()
uxcell a15010500ux0444 50PCS 16mm… https://www.amazon.com/dp/B00WW71JUE?ref=ppx_pop_mob_ap_share
Not sure if this is helpful but I bought this build from my buddy @Skyart he’s using plastic O-rings, Genius thought I’d share.
