So as long as it’s something small, uniform and fairly strong it should work well?
Why do both motors have a section where there’s no battle hardening?
When all taped up, the hall sensor covers the gap that you would otherwise inject/drip epoxy into. Could be added later. The was a test run.
Would it be possible to use the epoxy without the beads, if you spin the motor so the eboxy doesn’t drip when drying?
Yeah, I had the same idea. Mine looked like shit and needed a lot of acetone clean up.
You could try taping the entire magnet surface leaving gaps to drip in epoxy. I understand the want to fix quickly and get out and skate.
Mock up, not actual syringe.
Just know that epoxy might not completely move to bottom of gap.
Where do you get your silica beads? most of the ones on ebay seem to be too big.
Unless something like this works: https://www.ebay.com/itm/Silica-Gel-Desiccant-Granules-Beads-Self-Indicating-Loose-All-Quantities/140688372885?hash=item20c1ae3495:m:mlZwQhgnzZLeA3VW7Hf03sw
I just opened up the motor with the clicking noise, but there doesn’t seem to be any loose magnets, yet the sound is still there. Could there be a different reason for the clicking?
- bearing
- adapter mount @ wheel
- almost anything else
Don’t use JB Weld on motors. It actually contains steel and will flow onto the magnets as it’s curing and destroy the motor
I’m using the 6374 motors that come with the Haggy drive system, not sure where Timo sources the motors from tho
So it could be that I’m was just paranoid?
is there a particular brand of epoxy that works well for this? I saw mention of 5 minute epoxy, but i’ve never seen that brand. I ask because heat and epoxy sometimes don’t play well together.
the video in the below thread uses Loctite Epoxy Instant Mix 5 Minute
