How bad is it if the phase bullets, sensor JST, or charge XT gets wet and short out?
Working on an enclosure adapter I can cast in epoxy so the connections and make them actually water proof but it would have an XT60, 2 sets of 1.5mm JSTs, and 6 5.5mm bullets in a row on the outside for everything to plug into
Hall sensors will be conformal coated and the charge port will have a 15A fuse inline
My old board had bullets integrated in the deck, so they were exposed to everything, spaced around 3 mm from each other. Iāve literally rode the board underwater and had no problems, but it was unsensored so I canāt comment on the JST
High-voltage unsensored motor windings are almost waterproof as-is, even without waterproofing. Iām guessing some extra-salty brine could make a small difference but probably not much. Itās mostly the low-voltage sensor assembly that gets messed up by moisture.
Ok thanks, I guess that would do it. Would hot glue also work (maybe a bit cheaper solution)?
In case I want to upgrade the motors would it be easy to remove the cables from the enclosure?
