Sounds good! get with me whenever your ready.
Awesome. It’s making its way through Ireland as we speak. I’ll let you know when I receive it.
I’m looking for a TB VESC. Does anyone have one for sale?
Original 4.12? Yes I have two let me know see here: https://www.electric-skateboard.builders/t/34-mini-cruiser-dual-6354-10s3p-caliber-44s/75273
anyone have a used hub motor?
My the PU on one of my old meepo hubs died.
This one: http://www.diyeboard.com/hub-motor-9052mm-500w-75kv-for-diy-electric-skateboard-p-537.html
Thanks
Yes, the 4.12 is what I’m looking for. Send me a PM and let me know how much you would want for them.
Thanks man!
Lol, I have a pair of used hub motors like that, first build. Used for a season so I’d sell them cheap (although they are from diyeboard). https://www.electric-skateboard.builders/t/budget-board-kit-vs-performance-board-kit-diyeboard-vs-diyelectricskateboard/58784
Why can’t you be in europe? ^^ I might need them if the police won’t return my board…
I wish I was in Europe
Just curious if anyone has any bergmeister hubs they could part with before I go buy a new set. Any color works
4.12vesc heatsink/enclosure
12s bms (d140 charge only for example)
and 12s charger (4A+)
A trampa deck.
EU
I’m removing one of these right now from a skate for an upgrade
You think the case will undo the effect of my semi passive air cooling my vesc already has? I usually max out at 20-30ish degrees Celsius with sub 15°c outside temp
EDIT : forget what i just said. The vesc is going inside a enclosure once my neoboxes arrive so my semi aircooling doesn’t play a role in this matter.
air cooling? Bruh, this is waterproof and battle hardened. No air getting inside. 20A battery max continuous, 35A for 10 seconds
I get my vescs up to 77c+ pretty quickly, hence the opening for cold air. ^^
the mississippi-proof esc belongs in an esk8 museum
That’ll be the Mid-West Riverfront Esk8 Archeological Museum in St Louis, Missouri. @b264 will be the first inductee for the hall of fame in 2020
Some new memorabilia will be on display by spring this year, a broken helmet, shreded gloves and the infamous Brian’s Box Punch! ![]()
My friend @DarkVortex is looking for an enclosure for a 10s2p 18650 pack (double stack) and Unity to go under his LY 40" Battleaxe. He was looking at an eBoosted enclosure but $100 plus shipping is way to steep for him
Also looking for an enclosure for a 121c Orbiter to hold a single VESC and 6s5Ah lipo, same deal applies
Whatcha guys got on hand?
P.S. message me if you have anything, he’s not active here
Send me a pm if you still need parts
