Wanted items cheap or free
Someone stepped up. Eagerly waiting for this missing piece
Have 360s if still needed. Have some to trade? 305/310s?
Sold
Same insides just slightly different cans. 190kv, sensors work, 8mm shaft. These are used but taken care of.
Was more looking for new
For a new build soon
Badda bump for a pulley in the US!
15T or 16T, 8mm bore w/ key slot, 9mm with a flange, preferably steel?
You mean 9mm this dimension right?
I have a handful but I think they’re all for 15mm belts.
I’ll check though.
Yup! I will check if I can use 15mm wide, the mount is kinda permanent so I can’t run wider belts but I think the wheel doesn’t interfere with the pulley
Ok I’ll shoot you a picture of what I got when I get home (hourish)
Aren’t those the kind @longhairedboy used to use? I bet he might have some in a drawer somewhere
Might be something you put in your post bruv. Dont know unless you say. Good luck with your hunting.
@b264 they’re yours bruv! PM your addy.
[US] Also need a VX1 receiver! Was helping a friend and the receiver shorted out over a heat sink and is now molten so I gave him mine…now I need a replacement
Got these in 15t
Both are much wider than 9mm like double
Awesome! Is the black one keyed?
No, it’s D shaped, it’s a haggy pulley.
I have 9s, 12s, and 15s in 16T with a double flange laying in a drawer.
shit I just realized that.
Do they have Ds or keys? And is it a center set grub screw?
I have steel key’d ones, but they’re made to fit 15mm belts and double flanged.
Hmm… I think I know why these are still in my drawer…
Keyless, single offset grub screw that I assume could lock into either a flat spot or a keyway.
With the end of the world fucking up shipping, I’d rather stay state side for a bit
Oh rip, the last pulley I was using on the small motor was relying on a set screw in a flat and it kinda ate the screw…
