Enough to give a couple away.
anyone got 12mm speed rings for mbs trucks? or can point me to a good set on amazon? need 8 but couldnt find what i need on amazon so probably searching the wrong term.
BTW… are you that k00ky guy on Utube?
Search for terms like this
Anyones has a xt90 antispark or two to sell?
Also need a 8mm bore 15t pulley
yep i do. pm ing
Why you gotta do him dirty and recommend Al washers that will crush in a relatively short amount of time
Because the OD of those washers are too big
And the ID of the washers I linked are actually 12mm
What are they going to interfere with on MBS trucks?
Nah the OD of my inner race is 16mm.
Never tried them but it might cause issues having an oversized washer?
Ok Boomer… small shim 2 account 4 small pp…
https://www.gobilda.com/2807-series-stainless-steel-shim-12mm-id-x-15mm-od-1mm-thickness-12-pack/
problem solved lol
Good find! Thanks for the help guys! And @moon
Still looking for a TB 218mm compatible Motor mount in the EU.
Dickyho mounts here.
I saw those. Not a big fan of grub screws. thanks though
I’ve had 3 lots of Dickho mounts and never have they let me down.
I know, not saying that they are bad. I just don’t really like things mounted with grub screws
But i may have to go this route if i can’t find anything else.
Take the grub screws out and drive a machine screw into the hangar, I think they are m4
If you wanna make it hella secure then tap the hole (thread through the clamp first) while the flanges are tight and red thread lock a 12.8 bolt in…that will last as long as the hangar
I intend to do that some time soon for the Paris trucks under my care
Update : Need the above +
12s bms (d140 charge only for example)
and 12s charger (4A)
