damn you are not in the US. Hardware stores usually have them here
Do you still have any? I am in need!
Not at the moment. I need to dig up the supplies and make more when I have the time
Anyone in EU got 2x 15mm 355mm or 360mm or 365mm belts?
I have 295 and 400, obviously off by a bit but if you have enough adjustment like an idler they might work. I can check my parts bin for a better size if you want though.
I have 395 Im about to try suspect even with idler will be too long
Anyone have a spare aps receiver or just their old one they no longer use or need? Shipping from aps is a pita
Anyone got some HTD5M 460mm 15mm wide belts laying around?
Looking for a battery meter, something that measures voltage, not percentage. For a 12s build. @b264?
The numerous cheap gauges have a button that toggles between percent and voltage
Do you have a link for a decent one? Figured you’d be the guy to ask.
quick amazon search does the trick
These work quite well, though you’ll need to power if from the ESC
Does anyone have a an uneven set of 90mm Abec ? The core on one of mine is deformed and wobbles. I’d like to buy one or two
Need one motor pulley, 8mm bore and must be at least 15mm width
Looking for 63xx motors, high kv
Still available?
If anyone in the US has a 310mm belt, hit me up! As long as it’s in decent condition, preferably 15mm wide but down to 9mm is still cool. I’m thinking a couple bucks for a single belt and a couple more to ship it?
Running 13:36 with 90mm center to center and single idler, maybe 315mm will still work?
Yeap, pm incoming
Can anyone belt me up? I just wanna set some thane on the road for science
