Here is a pic showing what .25 off looks like.
I think I would have to remove top and bottom side flanges, weather strip it and bracket it down from the enclosure sidewall to the board. Alternatively I could cut a 2" slice or so out of the center portion and re-bond it with some fiberglass mesh and ABS cement. I think the latter would be a more aesthetic result.
It’s yours if you want it.
Definitely, Ill take it
Would someone be so kind as to hook me up with an NTK 100k temp sensor for use with DieBieMS? I’m in Miami, FL
Anyone in the EU got a spare VX1 pro? I missed the sales they just had lol
Anyone got a 465mm belt or longer?
I’m sorry I don’t but I am curious, what setup do you have? That’s a good sized length.
Motorized push stick, 165mm wheel and 63mm motor can in the same plane, and a 14:72 gear ratio
Ah I didn’t think about big pulleys, GL!
Also maybe a MakerX Go Foc 4.12?
Looking for a lightly used 10s3p pack.
Gotta fit:
415 * 160 * 40 mm
16.34 * 6.3 * 1.58"
I wanna make one of them so bad
Does anyone have a loop key harnest( like the thing that connects to the battery and esc and the loop key) or just an xt90?
XT-90E is what you want.
I’ve been sneaking parts into the research project orders for a bit now, I just need some hardware and the aluminum extrusion and I’m good to go
I’ve got some 0.125" laser cut 7075 bits to hold everything together
Are you not at a stage where you’re comfortable soldering? Because that is easy AF to build if your skill is decent.
I have one that I think will fit. It’s 10s3p 30q.
Actually nvm it’s a bit too tall.
