Wanted items cheap or free
“standard” SS - I’m using the DBS precut nickel strips
Thus, the pack is 8 cells across, and 5 long.
If I had to guess at dimensions I would say it’s approximately 25-30mm tall, 170 ish wide, 350 ish long
Clear Battery Heat Shrinkable Tubing,3m (1Roll) of 0.15x250mm Battery Pack Wrap Heat Shrink Sleeve for 18650 21700 AA AAA 18500 20700 26650 Battery Pack https://www.amazon.com/dp/B081Q3M6CR/ref=cm_sw_r_cp_api_glt_fabc_P5NSVHMXDRGXBFRQQ6ZJ
250mm is what you want
Ah perfect thanks so much Art
To the welders out there, looking for a couple pieces of aluminum brazing rod. Help a brother out to finish two projects.
Looking for a Maytech 6374 HA-C motor shaft. Mine has the key stuck in it, and no amount of blow-torching is working.
Cut it out with a dremel cutoff wheel that has been worn down())))Slice it right down the middle. @rusins
Will try, but I’m pretty sure I’ll just end up with a shaft with a cut-up key stuck in it then :laughing:
I have a set of dual 70kv meepo hubs $40+shipping if u want them, no hall sensors since they died, work fine sensorless. Sleeves r a bit worn, down to 89mm u can still get hella use from them. U will need to resolder on some bullet/banana connectors.
Wanted …bindings for mountainboard. Prefer mbs f2 but whatever ya got pm me. Open to anything. S.C. Merica
What’s your location?
South Carolina
Ah, I’m across the pond.
Anyone have a couple solderable female inline XLR ports?
ISO just one Tb 110 wheel
Those look brand new @TnA
They are except this one keeps delaming a little bit with every ride due to curb impact.
bet ill hit ya up when i get paid(wednesday night so realistically thursday). got a hanger and/or baseplate theyll fit on, or cheapo esc? this snuck under the radar on my notifications lmao.
I happen to know @PropulsionBoards has three on the shelf since they RMA’d one for me. Perhaps they’d be willing to sell you a single?
Yeh its already on a paris clone truck, as for esc naw they r fairly hard to get new, let alone used if ur looking for a vesc because of a chip shortage.
lol its all good, ill slap a cheap FOCer 2 on it most likely, and imma have spare cells after this next round of building. as for the sleeves, ill buy a couple bike tires and make new ones outta those, gives me an excuse to do the same to my hyperdrives. for science. i also have some blue cags thatll work for the front, and several spare calibers. shyyyytttt i guess that makes 10 builds year one if i finish everything out by new years. \m/
