Cool cool thanks, no hard feelings if they take it anyway
I got an idler from Nexus Boards in the UK (canāt remember the @ sorry) and Iām pretty happy, but wondering if anyone has recommendations for them because I need more now and UK shipping is a bit of a pain, half the stuff gets delayed at the border to Ireland
Ill buy used singe vesc from someone
What country are you in?
Im in Ukraine, but i its ok to make delivery in one of these countries: USA, GB, Polland or Germany(there is companies that deliver goods from these countries for cheap)
Iām looking for a charge port for my 10s2p 30q Battery, I have only found packs of 10 but I only need one!
Iām from Germany.
does anyone have 2 Fivestar Hubs they want to sell? just two
Anyone got a spare motor shaft for a Maytech 6374? I cannot for the life of me get a keyway off mine
I have a few of them but shipping to you is gonna be more than theyāre worth. I somehow broke mine so I contacted Maytec with pics and they sent me a couple new ones free of charge. But if yours is not broken and you donāt want to break it then you might try a dremel or grinder. Maybe torch if itās glued on?
Tried torch
In all honestly I can probably still use mine, just need to assemble the motor in a non-standard way. Just trying to weigh my options
try freezing the whole thing (leave it in the freezer for a day or 2) then torch the shaft end without the key way.
an other way, you can use a flat screwdriver a hammer and beat that shit out lmao
ik iām an artist
Good idea! Iāll try that and let you know if it works
Edit: it did not
If you canāt get the key out, then you also canāt get the shaft out of the motor. I guess unless you grind the key off.
We used to do this at robotics competitions, we used a thinned and sharpened screwdriver to get under it and use leverage to pull it out
Actually, as I was hammering away at the pulley initially stuck, the impact actually drove the shaft through the other end of the stator. So I unscrewed the grub screws and took the can and stator off
I took this wheel apart because reasons and I cross-threaded one of the through-bolts and completely mangled it. Does anyone have one?
Itās an evolve wheel I think? Maybe?
Maybe not actually.
Iām in Vancouver, Canada.
I picked up a handful of them from my local hardware store. Just take one in that isnāt mangled and match it up.
