Wanted items cheap or free
[WTB]
Hello! I am looking to buy 1 meter of 200mm width heat shrink for my battery :D, if anyone has this in Europe.
Looking for two of the below:
I am working on a dual motor TB 6380 with Maker X mini FOC PLUS. Need a way to wire the female 1.5mm JST (TB Motor) to the 1.25mm JST (Maker X VESC).
Add your location to your post and profile
Cut and resolder. No point in adding more connectors
I can solder decently, but these little plastic wires always give me trouble. Are my temps too high?
Also. would like to avoid modifying the motors in case I decide to sell or change VESC down the line.
Chances are the buyer will be happy of this if you do a decent job
Chances are the original connectors won’t fit that one either :joy:
If you pretin the wires, should be a 5 second per wire story. Just don’t forget to put a piece of heatshrink before you solder them together…always hurts doing a beautiful solder and notice you forgot that step :joy::man_facepalming:
https://www.amazon.com/gp/aw/d/B07J3V7SB3?psc=1&ref=ppx_pop_mob_b_asin_title
Thanks @Flasher. I’m thinking I’ll copout a bit and try @J0ker connectors to join the wires.
Now to double check that I wire them correctly. It’s my first time running sensored. Could I get some confirmation that I won’t blow anything up?
Wire configuration:
Maker X = VESC
  • GND = GND
  • H3 = C
  • H2 = B
  • H1 = A
  • T = Temp
  • VCC = 5v
PS: Am I not allowed to edit my replies in some threads? I have not seen the option recently🤔
Yeah that looks right, you can shuffle the hall sensors any which way and it doesn’t matter
Make sure to get the thinnest shrink wrap tubes you can and put them on first
Guess we can’t say often enough
Counter point: In this case, it isn’t too bad since you can just de-pin if you forget.
Still: Don’t forget the heatshrink
Hi guys anyone here selling a new davega x?
Bumpity bop
Looking for 25-30mm wide nickel, need some fast.
me too. :slight_smile: several of us have wide nickel on the slow boat though. the glut should be over some day.
I have some ordered but need to get a batt done up soon for my buddy @DEEIF. (He kinda impatient)
Same. Hopefully it doesn’t disappear into nowhere-ville like my 12mm nickel did :roll_eyes:
At this point I have no hopes of getting that and will probably be asking Ali for a refund
Anyone have 11 m4 cone washers, 11 m4 15mm socket head cap screws, quarter inch braided sleeving, or 12awg red and black wire? Appreciate the help
I Need a 12s D140 BMS if anyone have one to spare.
Possibly…
