Still relevant?
Iām starting to think I might need more⦠Unless you have 2 pairs of 8mm bullets as well I think I will pass and just restock my inventory
8mm bullets???
Nope, have none of that, sorry.
Thanks anyway @rusins!
Looking for 44T pressfit kegel pulleys
No matter the brand
Just something I canāt fail to mount (have dickyho pulleys and canāt get the plastic tubes into my TB110s)
Why not to use just basic switch? Iām struggling to see how this would be useful.
You know youāre not supposed to use the plastic tubes when you use the pulley as a press fit right?
The tubes go in to the 5 holes that have screws, they only go in from one side and you need to hammer them in (I use a wooden rod to not damage them)
Really, lol?
On dickyhoās instructions he does it for each sideā¦
Iāll try it out tomorrow, thanks for the hint!
Without the screws it wonāt stay in the wheel ^^
I canāt figure out how to pressfit install this⦠Am I dumb?
I mean the core has a taper, you canāt put them all the way through
Looking for two 44T pressfit kegel pulley, with big inner diameter (should fit TB218 with no filing) and two 290mm HDT5 belts, either 12mm or 15mm, depending on the pulleys
Is this what youāre looking for?
I saw another, but you may need a 3d printer to make it.
Hey, did you ever find 15mm spacers? My boardnamics 220 hanger needs themā¦
Local skate shops should have bearing spacers. Also, in a pinch, you can usually get away with throwing another bearing on it, but bearing arenāt as cheap as spacers.
Quick tip too if you have broken bearings, you can pry out the race and take the balls out, then use the center piece as a spacer. I have two of these on my front wheels, works pretty well
I just took some M8 nuts and drilled them out with a 5/16th bit, works like a charm
If you need one, PM your address, Iāll send you one for free
(if itās for 5.5 x 2.1mm barrel jack)
