Look up markdown formatting
I’m on mobile and it still works easily
Nah bro otherwise I would lol
Looking for some 25/30mm wide x 0.2mm thick pure nickel if anybody has some
Does anyone know where I can get 14 tooth motor pulleys for a 10mm shaft?
Basically I have the new Trampa OBD system and a maytech 8mm motor shaft is too small (26mm). It would be great if they made 8mm shafts with a 34mm output but they don’t.
Stuck on what to do! Either buy new motors and pulleys, change the Trampa bearing to suit 10mm shafts or buy the over priced Trampa motors. I know what I’d rather do!
Same issue as @ShutterShock I think
I have some I don’t know what size but I’ll measure them after I do this sleeping thing…
US looking for o rings for bergmeister tube valves (16 x 8 x 4 mm i believe)
Harbor Freight has a box of o rings…I’d imagine other hardware stores do too
Found some that fit at Lowe’s, thanks brodie
does anyone have any Dickey Ho motor 10mm D-shaped motor pulleys that I can buy?
This is where I get mine:
I’ve only been able to find 15T in a 10mm D-type, and I’ve looked a fair bit.
I appreciate it!
Anyone state side have a 7 pin jst-xh pigtail?
Anyone have 10 spare 30qs or similar cells? Doesn’t have to be new, will obviously pay for them
Currently totally invested in 6X2 (~150x50 ) pneumatic setups on both my board and a ton of spares but thinking of trying 200Xwhatever if anyone has a set (tire+tube) lying around that they are not planning to use.
In exchange I can print you a pair of pulleys of your choice in Alloy 910 (really tough Nylon) – will last you thousands of kms–, or something of similar volume.
Hi, how many Tooth you need ? I have two 20T 10mm D-shaped let me know what you think?
Are you sure those work on c6374 motors? They are 10x2 and not 10x1.5? I havent got those but when i used to sell them i didnt think they would fit
Yup, running them on those exact motors right now.
