Awesome - it would be great if we can tweak this 0.1v param. As an example, i had an issue with one series pack, where due mechanical stress 1 cell pop off…below is what i had, less than 0.1v…it was a 6p , so the voltage held quite welll (but this was a new bat though).
And magically the account and settings tabs work perfectly all of a sudden!
Not sure if the app was updated recently, but praise the gods @rpasichnyk @janpom ![]()
Small request, would we be able to get the icon changed to a circle to match with everything else on WearOS?
Only reason is that on my watch face, it looks not so aesthetic:
Personally I would also enjoy less white, I’m not against white, just less would be nice.
Also praying to the gods again for a WearOS complication that shows a chosen board stat or two.
No replys i guess this is no??
Possible different time zones and people also have busy lives… give it a few days
So far is seems this dynamic duo replies to update requests in the form of… Updates.
Keep an eye on the play store and make sure beta updates are turned on for the soonest response. ![]()
lol…17days is quite a bit of timezone. Sorry, just being sarcastic, i know you’re trying to help.
Yeap, no worries man…i am just a heavy user with some issues testing toys
You and me both brother
I was trying to be smart and reuse icon files from the android app with symbolic links for the WearOS project, but it does not seem to work that well. Thanks for pointing this out, I hope I fixed it now, update coming soon.
Sorry for not replying earlier! I think what you mean it is not supported in Metr app → Expert tab (only for configuration / changing parameters of the BMS). You should still get realtime data from the BMS: cell voltages and everything. Is that correct?
no worries - Yes, it’s on Metr app “Expert” tab the screen shot with firmware compatibility warning. On Voyage app, i get the cell readings correctly, but i dont get anymore the little drop on each series that tells when group is balancing.
Hello guys, @janpom @rpasichnyk
Trying to order Minnie, unfortunately no shipping options for Serbia…. Anything we can do about it? ![]()
New WearOS Voyage update today:
Icon is still square.
Sorry about that, we didn’t have it configured. Now added!
Does it help to completely uninstall the app from the watch and install it again?
Thanks for the info! I tried to look up Ennoid 6.5 source code, but could not find it, looks like the GitHub repo hasn’t been updated yet GitHub - EnnoidMe/ENNOID-BMS-Firmware at ENNOID
Maybe I am looking at the wrong place? I can add support once the sources are available.
thanks for looking into this - the support from you guys is amazing.
Please look directly into their webpage, there’s is dbc file there and firmware infos:
Noticed an issue today, the majority of this ride isn’t logged/tracked at all
The start is tracked, and the last few kilometers are, but it’s like it cut out as soon as I left town and kicked back in after I stopped for a water break.
On my case, i stopped for a flat tire, and it did not logged anymore. I thought it was just a transmission bug, but it might not have logged at all.
During the non logged part, i noticed my android wear crashed and did not connected anymore (not sure if this is related - just sending more info for troubleshooting)
