How do I view my rides logged by the Minnie?
Account tab still makes the app freeze.
Not sure if 12h clock is implemented yet, I have the beta update and I canât find the option anywhere
Edit: also the trip odometer never resets, it has only ever gone up.
If you have Imperial units configured, other values are in mph and not kph, the clock should be 12h. Or do you want to have kph and 12h clock?
Yes I want metric, Celsius and 12h.
I see! We donât have a separate setting for 12h yet. We will discuss internally. Does it switch to 12h when you use imperial?
Yes when I switch to miles instead of kilometers the âAMâ appears under the clock.
Iâm also noticing every time I open the app it opens to a blank screen, I need to go into multitasking and remove the app from RAM and relaunch it for it to display anything.
I have one suggestion. I mainly use the website on my PC rather than metr,voyage connect, so it would be nice to have a function to add small notes or captions to the ride log section. I donât have many ride records yet, so itâs okay because I remember them, but later on, it might be hard to find the ride records I want to see again if I donât know the date ![]()
Map doesnât help? I imagine you would at least remember the location of the log youâre looking for, right?
Thanks for the suggestion anyway. Though I canât currently promise weâll do it, I will keep it in mind.
Yes, of course, itâs good to be able to check it intuitively on the map. However, if itâs a non-overlapping course, itâs easy to distinguish, but if you ride a specific course solo or in a group, itâs not easy to distinguish when you rode that course solo or in a group by looking at the log from a few months ago. As more logs accumulate in the future, itâs likely to be even more so.
So i ended up cracking the glass that covers the screen on the davega, any chance i can find a replacement?
When I fixed Ashâs Megan, I just added some extra foam and mounted the screen directly with no glassđĽ´
Curious if itâd be possible for a replacement
@janpom if youâre not making/selling davega replacement glass anymore, could you publish a dxf file of the outline? That way people could have replacements cut from sendcutsend out of acrylic, for example.
I found the button to merge ride logs. But can I also cut a ride log in two?
I was playing around in front of the house and that changes Wh/km and max speed for my 20km ride before.
Sure, here you go. This is for DAVEGA:
acrylic_screen_protector.dxf (4.2 KB)
acrylic_screen_protector.pdf (1.5 KB)
I donât have a .dxf file for Megan protector but these are the dimensions:
No, thatâs unfortunately not possible. One of the changes that should happen soon is how we merge logs. Rather than discarding the original logs, we want to group them and then allow viewing the group as a single log. That way data is never lost, even if we have a bug in the merge algorithm.
Then it should also be possible to ungroup (split) the group, so if logs are merged by accident it will be possible to undo.
This is of course different from splitting a log thatâs not a group. Iâm afraid we wonât be implementing that one since itâs somewhat complicated regarding the UI and the use case seems rather rare.
Got you. Thanks for the explanation.
@janpom - I had a FlexiBMS where i could see the cells balancing by a drip water mark next to the series group. But i am now using a newer ennoid V4 (ENNOID - XLITE-V4) and i canât see that mark anymore when balancing. Surrelly something about the firmware. Can you pls take a look? i used a lot this feature in the past.
I can see Minnie is logging BMS cell voltages and temps (which is great!) - it would be great if we can somewhow visualize that. It could help to dignose batt problems/constraints during riding
Yes, we are incorporating BMS data into the ride logs, for now it will only highlight areas where BMS voltage mismatch is greater than 0.1V (with RED)
