Android Wear is in progress. Round watches make it more complicated, we need to account for that.
Historically, watches have typically been round.
I am not arguing with that, itās just Megan display is rectangular and we wonāt be able to apply the same layout to a round display.
Making progress with Android watches
Question on the minnie can.
Is there any chance i can plug a vesc express into the minnie?
I found this new remote that i really like, but the minnie is already plugged into the can port.
The remote works through vesc express via can.
It should be possible! Minne comes with JST PH 2.0mm connector, looks like you can plug it in VESC Express. Just make sure CAN wires go as they should (5V-5V, GND-GND, etcā¦)
One more question.
I have a skp solo dual with the metr module pre installed.
What would i need to do to get a vesc express working with this setup?
You need to connect VESC express to Solo via CAN cable. Should not be harder than that.
Will the WearOS version support complications? So I can have info on my main watch face?
Cool, so just install vesc express between both esc on the can.
CANBUS is a network, all devices just need to share the same H/L busses
And each device needs a unique CAN address, in the range of 1-255.
Iāll have a look into it. Probably no complications for first release, to get it out sooner. But should not be too hard to add complications after everything else is in place.
Mmmm nope⦠modes just acting weird and i donāt know why nm
Beta for Android Wear OS watches is out!
Does this⦠Mean the app is standalone on the watch?
So could I theoretically leave my phone at home? I wouldnāt, but could I?
Yes, itās standalone watch app, no phone required.
@rpasichnyk Motor Current Value is Dual? Or Single? and
How do I see my trip (mileage while Esc is on) on my megan? The trip on my megan screen shows the cumulative mileage like ODO.
itās dual unless you split it with the drop menu. you should be able to edit the layout and set one of the info squares to trip mileage in the voyage connect app
I have my voyage layout set up in the app to my liking, but I guess I didnāt see it. Iāll try it, thanks ![]()
