What remote are you using instead?
There really shouldn’t be. Hrm. I’m wondering if it has to do with how the ADC sampling is handled, I seem to recall it did an filtered averaging of some sort which could introduce delay. When new Wand firmware gets posted I can take a look.
Important to note that even though the NRF chipset has Bluetooth connection support, it uses a different, low latency, radio protocol for the throttle run-time connection known as ESB (Enhanced shockburst).
I will do some side by side testing, I have my own NRF hardware I’m testing on but it’s not based on wand firmware. I’ve not measured any noticeable packet latency unless it was a range/connection limitation test.
I immediately noticed a considerably more direct response with the PWM remote, I didnt realise how much latency is factoring into the feel of the NRF connection.
That is adjustable in the remote app. Positive ramping and negative ramping…
Your first remote, the one I swapped had a good poti btw. There was some water inside after the ride in that terrible rain.
The stock values for the vesc tool are 0.4s and 0.2s.
The are too high IMO and you are better off setting them to 0.2s and 0.1s
Depends on how practised you are. For beginners it is hard to adjust to a very direct throttle.
Just send us a mail and we can swap the PCB.
What are the stock values for PPM mate?
@tipsy back to the VX1 whilst I wait for the new OSRR hardware to come from @DerelictRobot
IIRC, 0.9 positive and 0.3 for negative
I just checked. It seems they are constantly changing.
Right now they seem to be 0.9s and 0.3s for both.
I just did the same.
Why?..
0.9 positive ramping can be kinda dangerous.
Oh hahah.
Well I never changed the settings for the NRF or the PPM just switched from stock settings on one to the other and the difference was really noticable.
Beats me. As far as I am concerned both values are way to much, especially the 0.3s for the brakes.
As I said I switch these to 0.2s and 0.1s.
They used to be 0.3s and 0.1s which were fine IMO.
@Lee_Wright which VESC-Tool/firmware are you using?
Recent releases have been a bit of a wild ride.
Yeah, and then with the Wand release it was updated to 0.4/0.2 (which is not great but at least not potentially dangerous).
I’ll file an issue report.
Sure, 100%. I kept it on my desk for testing. The NRF chip or the soldering got damaged.
@Lee_Wright 's Wand today:
@Trampa
Is the potentiometer issue common? How much a “military spec” one would add to the cost? It’s not a budget remote, why not make it the best
If you want a military spec thumb wheel: They start at 60 to 100USD per thumb lever, purchase price fro manufacturer.
The poti issue is not so common and easy to fix. The Wand is the only remote that can detect a faulty poti and that can filter bad signals from a faulty poti. On most skate PPM remotes you will find very similar thumb controlled potentiometers. They simply don’t tell you when they are warn or give strange signals from time to time.
