In the mobile version, is there no way to enable live packets (heart) so i can run foc_openloop?
The Issue with a broken motor sensor is not the risk or bringing the 5v rail down, its the risk of getting an incorrect position reading and trying to drive the wrong motor phases as a result. This cause cause huge currents through the ESC which can damage fets or blow the DRV.
In theory yes, but in practice the Hall PCBs and hall hall probe legs were more likely to short out than a simple probe that is pretty well insulated and uses thicker and more sturdy cables. Also there are 3 Hall probes vs. one temp probe. And there is a 10K resistor in the Temp line while PIN 6 of the SESNS port has a direct connection to 3.3/5V.
Second problem with sensors is the wrong signal reading they can give and that can cause potentially HW damaging effects.If we can save away causes for trouble, it is a good thing. One part less to worry aboutâŚ
sturdy wires probably doesnât help with temp sensor noise, which is the reason a lot of us have disabled the temperature sensors.
I may have misinterpreted, but felt like jeff was just saying, with a lot of motors⌠weâre just fâd. ![]()
Simply cut the wire and glue the temp sensor to the front side of the coils for example. Running the sensor cables above the spools is no good idea. Our motors had the hall pcb in front of the spools to avoid this issue. Fast spinning stong magnets above a wire carrying a signal is not the best design choice. Riding without temp feedback is also no good idea.
A new beta software is online: Firmware 5.03 | VESC Project
Sensorless startup should now be almost perfect if itâs a VESC HD or VESC6MKV or 75/300.
It also features a new wizard for e-skateboarding.
Iâm not sure if it wasnât already addressed before, but I very often have issues to setup my vesc based escs via can.
Mostly when starting the input wizard I get the âall vescs need to have the same FWâ message, which doesnât allow me to go further with the setup.
Switching on of the escs, starting the vesc tool new or switching the esc Iâm connected to usually fix that.
I do have this issue with all kinds of vesc based escs as well as with a set of vesc 6+.
FW is 5.1, not yet ready to change to a newer version
This is exactly what Iâm getting trying to do detection with the new 5.03
So âHFI Startâ mode is sensorless + a little HFI blip?
Do I have to do any of that annoying HFI tuning process for it to work as intended?
Nope, it should work without tuning.
Sounds like riding ass is going to be easy. Huge improvement over hfi.
edit: I retract this statement. Doesnât looke like ASS works on just 3 phase wires, you need sensors
So ass is like a self configuring hfi? Any improvements regarding the noise?
Self configuring, no noise.
Went on a test ride with âHFI Startâ mode.
Sometimes startups are smooth, sometimes pretty coggy. About 50/50 I suppose.
My gear ratio is pretty favorable I think, 14/44 @ 110mm wheel.
Measured and wrote the Offsets section before doing detection. Phase filters enabled. Temp compensation is on as well.
Just run the detection, do not measure the offsets.
@Trampa did Ben pull out this beta download? I canât download it, even when logged in
For me the current download link on the vesc-project forum works fine.
Iâm having this issue with 2 vescs and 2 motors already.
Happened with Neobox v6 on hubs and 6374 motors. Was fixed after going from 5.02 to ack 3.103 to 5.02
Now having the same with the unity. Did not happen with the latest UnityFW - does happen with 5.02
Even setting duty cycle to 87% doesnât stop it from causing this behavior
Unity was flashed minutes prior. Motor and Input were done completely and both settings were saved.
Almost everything is stock VESC configuration except the test with duty cycle, battery current max and what app to use.
this is how the graph looks like. The big red and Blue spikes are when the crackling occurs.
UPDATE: i flashed 5.01, redid everything and the sound does not appear anymore.
Update 2: Nope, it does still appear but later on the throttle.
Update 3:
Does not happen on UnityFW.
Happens on 5.02 (detection on PC)
Happens on 5.01 but later (detection on PC)
Happens on 5.01 (detection on metr)
Does not Happen on 5.01 (detection on Vesc tool android)
On my phone I managed to download now
Want to give ASS a try
Some more infos regarding this problem.
The last point âdoes not happen on fw 5.01 with detection on vesc tool androidâ HOWEVER it does reappear when changing Duty cycle current limit start to 0.85. If the stock 1 is set, it disappears again.
Also happens on 5.03 with duty cycle limit start at 0.85 and 1
