VESC-Tool 2.04: FW 5 >> A BIG STEP FORWARD
Just wanted to let you guys know, the stuff regarding max duty cycle is on Vedder and My radar.
Vedder has pretty good theory on what is going on, he made the maximum duty cycle limit work better which is somewhat ironic. Basically before as you approached max duty it wouldn’t correctly prioritize Q-axis current (the current that makes torque) over D-axis current (no torque). Now it does this more efficiently which is good, the problem is it causes a more abrubdt feeling torque loss when the limit is come up against and can cause oscillations with some setups since it is a rapid change. The solution is to soften the change as per the setting @Trampa is pointing to.
I’ve talked with Ben about the best ways to add this into the wizard for next release. It does cause a slight decrease in top speed power in the last 5% so people on e-bike or expert users and other applications might not want this limit imposed without being informed.
I have that limit set to 85% on all 4 escs, but still getting oscillations on profile limit 40km/h. When I set 30km/h it’s ok. My setups max should be about 50km/h.
What if it’s also caused by every motor having slightly different erpm? Like when wheels have different pressure, so on the same speed you get little different rpms. But traction control erpm difference is at 3000 erpm…
I just lowered mine from 2000 down to 1000 and it was all sorts of fucked up. What works for you might not necessarily be best for everybody else.
Has anybody else experienced weak torque on startup with HFI? My board only delivers torque once it is well and truly rolling, no off the line punch. Funnily enough tho, in ‘current’ mode, reverse has heaps of punch :thinking:
I tried inverting motor directions with the same result. Forward sucked, reverse was great.
Wtf?
Well the solution is right in your face. Change stance and use Reverse as forwards, forward as reverse. duh.
That’s a work around, not a solution.
I’ll see if I can get similar behavior this weekend.
You may want to change the % limit for the start also then. These limits are essentially P controllers which can become unstable in certain setups.
Personally I wasnt satisfied with the workaround duty cycle current limit start “fix”. It made the full throttle motor wobbling issues go away but my top speed was lacking. It felt like my board was sagging while reaching top speed.
I understand that’s what the duty cycle current limit start is doing but I couldn’t continue to ride with it unfortunately.
Major bummer because I was really liking the profiles feature.
Speed limits, set in the profiles, automatically apply a duty cycle current limit.
https://digitalcommons.unl.edu/cgi/viewcontent.cgi?article=1343&context=electricalengineeringfacpub
Interesting paper I found. It might provide an alternative HFI strategy that allows for greater power flexibility.
I just tried on a new skate, and the HFI sucked ass at any kind of low setting.
I think it might be duals, maybe duals have to be high.
The single drives, you can put it at like 750erpm and it kicks ass
Hey @deodand what phases are the vesc current sensors on?
All :thinking:
Three shunts, three meassurements, one per phase
How’d you go over the weekend mate?
@kalebludlow
4.x hardware only has shunts on phases A and C I believe
And during HFI and low modulation it only uses the measurements from two phases, can’t remember which two, it’s somewhere in the code.
Yeah I need phases B and C, just wanted to check which ones low modulation uses as that’s what I need
Is there a walk through tutorial on how to run 5xx FW on the unity for dummies like me?
You can just follow the regular VESC-Tool tutorials.
Yeah go ahead and follow the video tutorials on firmware updating and then everything else.
Pro tip: dont think of it as one vesc anymore. It is two separate vesc’s connected by CAN. When changing settings you have to make sure you repect the CAN forwarding. The wizards will write settings to both vesc’s, but manually changing a setting does not write to both unless you write to master, CAN forward, write to slave.
Is there a pc video tutorial? I have a iPhone so vesc tool mobile is not a option
