So I have a TB Vesc I got from a forum member here for one of my friend’s builds and I’m trying to get things programmed. Plugged in the Vesc and it said the firmware was too old, went to go upload the firmware and it just took forever and timed out.
I think the bootloader wasn’t installed correctly, so I grabbed an stlink and reinstalled the bootloader (or so I think). Blue and green lights turn on, and red light blinks 3 times when plugged in. I keep trying to update the firmware and it goes through the process of updating, but every time I go back into the tool, it says the firmware is still too old. Please help…
Downloaded the 2.54 tool and tried to upload Ackamanaiac’s 2.54 firmware, and the Vesc just wont budge from its 2.18 firmware, no matter what I do @BillGordon
Jeez, I guess this vesc is just non-compliant. Downloaded the 3.103 tool, and the default bin file and tried uploading both through the custom file and included file tab.
Still stuck on 2.18
I could technically run it on the 2.18 bdlc tool but we all know it’s just not the same…
Is there any way to completely “erase” the Vesc and start over? I know that’s what reinstalling bootloader and firmware is, but anything aside from that?
Like already mentioned flash the bootloader first.
Some escs come without bootloader so it is not possible to update the firmware until you upload the bootloader.
You can do that either through the SWD port of another esc or an ST link.
