When I hit throttle, the motors do not turn and my Davega throws error code pictured. The left wheel turns just fine. The right wheel has a lot of resistance turning. There is no overheating or noises that I can tell. The code says VESC Fault DRV Fault. I do not have any tools to test the motors or controller. I cannot tell if the motor shorted or the controller went bad. Any insight would be appreciated.
I have 6384 190kv Flipsky motors and and Stormcore 60D controller.
This is sometimes caused by a loose battery connection, but more often than not a DRV fault undicates the VESC is probbaly no longer going to function.
Sounds like you have a classic case of stormcore nomore. Open up the board to confirm. Or a motor died, but that tends to also take escs with it. Check the stormcore, then follow the above guide for checking your motors
